Diesel pump leak
Bongo boy
Diesel pump leak
Post by Bongo boy » Sat Jun 01, 2013 10:30 pm
Hi everyone. I have a leak on my pump on the back. I have got seals and carefully remove the front cover. Put in a safe place. I then replaced the rear seal. All was going well until the front bit got knocked over. There is 2 washers/shim I don't even remember seeing, 2 springs and another piece that I can describe as a cup washer. How does it all go back together. This is how I think it does. The dome then 2 washers/shim then the springs then the cup washer thing. But what way round does the cup washer go.
Thank you
Re: Diesel pump leak
Post by Northern Bongolow » Sat Jun 01, 2013 10:49 pm
click this link, in it are several other links to how too,and fuel pump exploded diagrams.
http://igmaynard.co.uk/bongo/forum/view ... mp#p532752
or this.
http://www.demonav.ru/For_work/104740-0824.jpg
or late pump.
http://www.demonav.ru/For_work/104700-0530.PNG
Bongo boy
Post by Bongo boy » Sun Jun 02, 2013 7:28 am
hi. many thanks for your reply. it doesnt really show the order the go in. i took some pictures of how i think it goes. im not sure how to upload them but here is the link to them
In pic 4 is the bit im not sure about. does it go that way or the other way.
https://www.dropbox.com/s/gse9z7x4cneq30b/photo%201.JPG
https://www.dropbox.com/s/xhqnwgpajzozizb/photo%202.JPG
https://www.dropbox.com/s/8uam5qt7cojzkr8/photo%203.JPG
https://www.dropbox.com/s/k5ajn0lhv2uzpb1/photo%204.JPG
many thanks
Post by Northern Bongolow » Sun Jun 02, 2013 11:50 am
the ring goes towards the inner, (pic 4) as in towards the face of the piston, the piston has a recess in its face to accept the ring.
yours (pic4) looks upside down as the thick edge goes towards the spring,and the thin side goes into the recess.
the recess must be for the ring as the larger spring nor the inner spring will fit into the recess. i always put any shims to the outer cap as they sit nicely on the peg inside the cap.
ive got 2 spare pumps and ive just pulled them apart for you. #-o :wink: .
the above must be right as ive resealed several running pumps including mine and they are running well [-o< [-o< :wink:
Bongo boy
Post by Bongo boy » Sun Jun 02, 2013 12:58 pm
Put it back together and all is well. No more leak.
Thank you for your time. Now to get it ready for my trip.
