There is a main fuel filter which is probably overdue for changing, but the mesh filter provides additional filtration including catching any fibres from the main filter element.
Hi,the later models don't have the strainer,if you have an early model you might need to look a bit closer to the aperture,sometimes a bit hard to spot.
