Front End Rumble
jl455
Front End Rumble
Post by jl455 » Fri May 31, 2013 11:34 am
Hi - I know this topic has been covered but I thought I would ask the question. When driving the I get a rumble from the front on both sides when going over rough roads. It seems to be ball joint type of noise but it reduces as the van gets warmer. I have jack up the front and there is no play on the wheels and the drop links look ok. So my question is: do the 4wd versions make these kind of noise's anyway and should they be quiet.
helen&tony
Re: Front End Rumble
Post by helen&tony » Fri May 31, 2013 2:33 pm
When you jack the Bongo up off the road, looking won't tell you anything. You will need a long metal bar to lever the suspension up and down with the bar under or adjacent to the component you suspect.
Post by Northern Bongolow » Fri May 31, 2013 11:04 pm
jack all four wheels off the ground then either run the engine/box, or try turning one front wheel, then one back wheel by hand, see where the noise is coming from. centre bearing on front prop/wheel bearing/drive shaft bearing/diff bearing.
steamysteve
Post by steamysteve » Fri May 31, 2013 11:34 pm
Hi .i had exactly the same symptoms. and it turned out to be the front tyres , had them all replaced with Kumo's and all is now running quiet. on inspection the front tyres had load of tread but had a ridge running in the centre of the tread.
Dodgey
Post by Dodgey » Sun Jun 02, 2013 1:11 pm
Ball joints and drop links produce distinct knocking rather than rumbling. As said, neither can be detected by looking and wiggling. You really need a pry bar.
As said, could be the tyres or a bearing.
jl455
Post by jl455 » Sun Jun 02, 2013 9:23 pm
Thanks to everyone for you response. Sorry for not responding but been away enjoying the bongo. I will do as suggested as it is a knocking sound, but it really isn't that bad now I'm putting some miles on it. It had been stood more or less for a year before I purchased it. The tyres are quite new and good quality (Firestone) but could be worth a try.
jl455
Thanks to everyone for your response. Sorry for not responding but been away enjoying the bongo. I will do as suggested as it is a knocking sound, but it really isn't that bad now I'm putting some miles on it. It had been stood more or less for a year before I purchased it. The tyres are quite new and good quality (Firestone) but could be worth a try.
