Does anybody know the tolerances/dimensions for a 2.5td 4wd
Looking at getting the laser aligning done but the two garages I went to that do it locally could not find the info?
Laser alignment
Re: Laser alignment
had mine done 2 years ago, it made such a difference. but im sorry, i just left it to the guy to sort the settings out.
as far as i can remember he just set everything to straight, no toe in or out.
Re: Laser alignment
You can do a search on here for info.
There is a factsheet if you are a member:
http://www.igmaynard.co.uk/bongo/member ... eldata.pdf
and a post on the matter:
http://www.igmaynard.co.uk/bongo/forum/ ... nt#p566536
