DIY oil change - no garage or pit available
agentdagnamit
Post by agentdagnamit » Tue May 28, 2013 5:34 pm
I'm due an oil change and have done one once before, but it was with the aid of a friend's garage that helpfully had a pit. That facility is no longer available, so I would have to do this on the street.
Is this practicable? If I drove the drivers side wheels on the pavement to lift that side up a little, would that make life easier - or am I best off buying the oil and filters online and taking the Bongo to my local garage?
wonkanoby
Re: DIY oil change - no garage or pit available
Post by wonkanoby » Tue May 28, 2013 6:02 pm
legal disposal of the waste oil is hardest part
the laird
Post by the laird » Tue May 28, 2013 6:33 pm
Most council yard have a facility to dispose of old oil
westonwarrior
Post by westonwarrior » Tue May 28, 2013 6:56 pm
unless its lowered or has a body kit there should be plenty of room to get underneath, I have several times
Catch the oil and put it in the empty container the new oil comes in and take that to the tip, should be able to pour it in a container there (you can in Weston)
Post by mikeonb4c » Tue May 28, 2013 7:03 pm
Or use a pela pump. That's what I do. No mess, no fuss, no need to remove sump plug :-)
briwy
Post by briwy » Tue May 28, 2013 7:20 pm
If you put the drivers side on the pavement it will tilt the van the wrong way to drain the oil as the plug is on the drivers side so ideally you want the passenger side highest.
Dr Fingers
Post by Dr Fingers » Tue May 28, 2013 7:57 pm
Having just been quoted £100 plus VAT for an 'oil service" (change oil/filter and not much else), not, BTW, by my usual source, I'm almost tempted to give this a shot..
but I am the world's worst mechanic.. :(
Should I??
Derek
Post by Northern Bongolow » Tue May 28, 2013 10:25 pm
you have the soundproofing under tray to contend with. it can be done with this on, as it has a cut out, but the oil usually hits this and splatters everywhere,
the oil should be dropped when warm so another reason not to get covered in it.
the oil filter has a guard over the top to protect it from exhaust pipe heat so best to remove the filter from below, if using a filter strap this is best done with the under tray off.
Post by Bob » Tue May 28, 2013 11:37 pm
I use a Pela Pump for the intermediate change (which doesn't include the filter) and have an annual service. :)
Post by mikeonb4c » Wed May 29, 2013 7:54 am
Bob wrote:I use a Pela Pump for the intermediate change (which doesn't include the filter) and have an annual service. :)
Yea, but its the Bongo we're discussing Bob :lol: :lol: :lol:
The_Gordons
Post by The_Gordons » Wed May 29, 2013 8:08 am
I use a Pela pump then dispose of the used oil at the local council household recycling facility. Personally I find the Pela pump a lot less hastle.
Bongo replaced by Wellhouse Terrier
lazyb5
Post by lazyb5 » Wed May 29, 2013 9:23 am
Northern Bongolow wrote: the oil filter has a guard over the top to protect it from exhaust pipe heat so best to remove the filter from below.
Wot guard :shock:
Post by Northern Bongolow » Wed May 29, 2013 10:10 pm
14-331a :)
some one knicked yours mate. #-o :wink:
mikeWalsall
Post by mikeWalsall » Wed May 29, 2013 10:19 pm
lazyb5
Post by lazyb5 » Thu May 30, 2013 2:26 am
:shock: think it's been nicked Ady, ill check when I get it back.
