head gasket
ali bongo
head gasket
Post by ali bongo » Mon May 27, 2013 3:08 pm
Hello , I am going to test the head gasket with a test kit, the one that changes colour for emissions in the coolant. Do I put it in the the radiator or the header tank any replies would be welcome. Thanks
Re: head gasket
Post by haydn callow » Mon May 27, 2013 3:22 pm
Do it in the header tank....but be warned......if it shows positive (gases in the coolant) then the head is cracked (almost never just the gasket)
But......if it shows negative it is often inconclusive and the head is still cracked.....the cracks are so small and the head needs to be well hot to leak the gases.
ali bongo
Re: head gasket
Post by ali bongo » Tue May 28, 2013 6:18 pm
Thanks for the info
