hair dryers
Moderator: Muzorewa
Baz and Helen
hair dryers
Post by Baz and Helen » Fri May 24, 2013 2:51 pm
Hi can anyone tell me what wattage hairdryer you can use on ehu, one site has 10amp and the other has 16amp. Could you use a normal watt dryer if you didnt use anything else while you had it on, electrics definitely not my thing. Thanks for any help Baz and Helen
Re: hair dryers
Post by g8dhe » Fri May 24, 2013 3:10 pm
The most powerful / hottest hair dryer is going to be about 1Kw(you wanted frizzled hair?), so that is 4 Amps (1000/250), so yes powered off the EHU will be fine.
Baz and Helen
Re: hair dryers
Post by Baz and Helen » Fri May 24, 2013 4:02 pm
Thanks geoff for the info, if my hair frizzed it would be a miracle not a curl of any descripition unfortunately. many thanks Helen
