Roof never stops beeping... Help!!
sarahjamjar
Post by sarahjamjar » Sun May 19, 2013 11:36 pm
Hi all - I am a relatively new Bongo-er so haven't really worked everything out yet. My roof was going up as planned but the last time I used it - it beeped as normal on the way up... But then wouldn't stop beeping unless the engine was turned off. I not sure that the roof was fully opened but it wouldn't go any further no matter how long I held the button down. Any ideas how I could fix this?
Thank you!!
Sarah :-)
wonkanoby
Re: Roof never stops beeping... Help!!
Post by wonkanoby » Mon May 20, 2013 2:45 am
help it up with a bit of a push
Post by Muzorewa » Mon May 20, 2013 5:51 am
Ours sometimes does this, when it won't go further if you lower it slightly and then raise it again it may be all you need :wink:
Post by rita » Mon May 20, 2013 9:48 am
Sound like the micro switch needs cleaned/adjusted.(Tweeked)
Post by francophile1947 » Mon May 20, 2013 12:47 pm
Muzorewa wrote:Ours sometimes does this, when it won't go further if you lower it slightly and then raise it again it may be all you need :wink:
I second that 8) - it happened to me regularly, especially if it was cold.
RobEvans
Post by RobEvans » Mon May 20, 2013 4:16 pm
rita wrote:Sound like the micro switch needs cleaned/adjusted.(Tweeked)
Where are they located cheers
TimC
Post by TimC » Mon May 20, 2013 7:31 pm
Not quite fully open. Give it a gentle helping hand and will probably shut up
mister munkey
Post by mister munkey » Mon May 20, 2013 7:53 pm
As said above, the last half inch needs a little help once things get to a certain age. A little spray of light oil on the runners & rams often helps. I used to use the cooking stuff in a squirty can from Crisp & Dry. Always worked a treat!
Post by rita » Mon May 20, 2013 8:15 pm
Its located on the offside of the roof at the rear.
Jerzy
Post by Jerzy » Tue Jul 23, 2013 11:10 pm
Mine carries on bleeping when I lower it - it seems to have shut ok.
Is there an associated 'down' micro switch?
loneranger
Post by loneranger » Wed Jul 24, 2013 7:26 am
Hello Sarah,this problem has been covered in a previous Topic about a week ago.The micro switch is located at the front end of the roof. There are two - One controls the bleeping, one controls the light on the dashboard.I had the light on my dashboard flashing all the time when the roof was down for over a year,and did what other owners have done and just covered it with black tape.But faced with an MOT fail because a warning light was lit I decided to sort it out.I found that adjusting the copper strips on the microswitch sorted the light,but now had the bleeper on all the time.I adjusted the other one on the other side and Bingo! No bleeping.Check the previous topic. Cheers Michael
Red & Blue Advanced Driver "Bongoin in the Peak" or "Aye Up My Duck" Land
Dodgey
Post by Dodgey » Wed Jul 24, 2013 3:10 pm
There is an advantage to the beeping not stopping.... when you put the roof down you can always do it from the driver's seat! - I never push mine the last cm to stop it beeping as this is nice and convenient :-)
Post by Muzorewa » Wed Jul 24, 2013 3:27 pm
....as long as you're sure there's no children / dogs / cats still up there :wink: :lol:
loneranger
Post by loneranger » Thu Jul 25, 2013 7:12 am
Not when it is bleeping all the time that you are driving.Now that is annoying.Cheers Michael
Post by Muzorewa » Thu Jul 25, 2013 7:21 am
One other thing to note is that having to press the "lock cancel" or whatever it is button makes you lower the inner roof, as the frame of the raised inner roof obscures the button. If you didn't have to press the button and just controlled everything from the driver's seat, you could lower the roof with the inner roof raised which will get the roof tent tangled up in the inner roof :wink:
