Anyway, i put her all back together as i took her apart and she starts and all that jazz. But a couple of things to note, number 1 was the valve cover had two bolts that were very loose so i nipped them up. Not too much. And the second thing is i noticed my glow plugs are 101mm long, but when i took them out originally i noticed they weren't bolted all the way in, about 1cm of thread showing. I have put them back in as they came out so as not too damage the insides.
Around one of the glow plugs i get a bit of bubbling of a fluid which i assume is diesel... ?
And i also noticed when i turn the bongo off and then just turn the key back on to heat the plugs i get a sound of air under pressure being released, also at about 15 seconds into the youtube clip below there seems to be a whistling sound.
Recommend i change the valve cover gasket? As i haven't got a clue when it was done last, plus its only 20£? And will i do any damage driving her around like this for a week or so?
http://youtu.be/kPNcale8lAw
Thanks,
Stefan!
I could go to a garage and spend a bit of money but i like to learn about it and try to fix it myself.
Quick edit, can i buy a bracket for my fuel pipes anywhere?
