3 way fridge
Moderator: Muzorewa
bongobaz1
3 way fridge
Post by bongobaz1 » Wed May 15, 2013 7:29 am
any body know anything about these???
seam to get good reviews and was thinking about getting one??
http://www.gooutdoors.co.uk/waeco-3-way ... ge-p115652
Re: 3 way fridge
Post by g8dhe » Wed May 15, 2013 9:37 am
Bear in mind that it only cools 25 C below ambient so no ice cubes, and no information about power consumption - however most absorption fridges draw between 75-150Watts which is between 6-13Amps which will cane a L/B rapidly, if you have a 90AmpHr L/B then you will only get 15 Hours of working.
Velocette
Re: 3 way fridge
Post by Velocette » Wed May 15, 2013 10:34 am
I have a 3way purely because it was offered cheap secondhand. It is not ideal but the regime I used for Spain, including a 24 hr crosing was as follows.
On the road travelling, run off LB. Stopped at campsite. Run off mains. Stopped at campsite with no mains. Take out of car and run on gas. To be honest we did this sometimes even when mains was available. They are happiest on gas but I don't want to be cutting big holes in the bodywork for ventilation so I only use it on gas in the awning or under a tree. Obviously lifting it out is a PITA which I can put up with but might not suit everyone. When we left home we had pre cooled the fridge on mains and put two big bottles of ice in it. This bridged the 24hours on the boat with no power at all there was still a little bit of ice in the bottles when we opened it the first time. Mine is a top loader, I can't remember what make.
The other thing about the absorption fridge is that they have to be pretty close to level to be able to work. Tolerance varies model to model.
Dodgey
Re: 3 way fridge
Post by Dodgey » Fri May 17, 2013 1:12 pm
Reading the specs the beauty of that fridge (which does seem able to freeze, on gas I imagine) is running it on gas in your awning, or on mains hookup. The reviews suggest it runs for weeks on a small gas bottle.
Jillygumbo
Re: 3 way fridge
Post by Jillygumbo » Thu Jun 06, 2013 6:44 pm
I have a Dometic 3 way coolbox. It works really well on gas, provided it is absolutely level. In fact, everything freezes up on gas and I have to turn it down 8)
They are heavy (due to the coils and bits for the gas) and bulky.
Works well on electric too.
I tend to use the smaller electric one unless I am staying "sans electric" for more than a few days.
Agree that it's economical on the gas.
Jillygumbo, Marvin & Lady
winchman
Re: 3 way fridge
Post by winchman » Thu Jun 06, 2013 10:45 pm
Dodgey wrote:Reading the specs the beauty of that fridge (which does seem able to freeze, on gas I imagine) is running it on gas in your awning, or on mains hookup .
You should never run any gas powered appliance in a tent or awning as you cannot ensure adequate ventilation. Even if you have a carbon Monoxide detector these are not designed to work in a tent, so best avoided
http://www.youtube.com/watch?feature=pl ... 2Vdq_Awnr8
Dodgey
Re: 3 way fridge
Post by Dodgey » Fri Jun 07, 2013 12:41 pm
I think people are referring to putting their gas fridges in a tent of their own - i.e. a storage tent, to keep it dry.
winchman
Re: 3 way fridge
Post by winchman » Fri Jun 07, 2013 5:22 pm
Dodgey wrote:I think people are referring to putting their gas fridges in a tent of their own - i.e. a storage tent, to keep it dry.
Would the tent then not just eventually fill up with Carbon Monoxide?
Re: 3 way fridge
Post by francophile1947 » Fri Jun 07, 2013 8:07 pm
I doubt it very much - most storage tents have gaps around the bottom. Even if it was fully sealed, the CO would escape when you opened the door.
There does seem to be a lot of scare stories about CO. Gas stoves give off CO2, unless there is insufficient oxygen to allow a complete burn of the gas - adequate ventilation ensures that no CO is produced.
Velocette
Re: 3 way fridge
Post by Velocette » Fri Jun 07, 2013 8:25 pm
It states in the instructions of my 3 way that it can be used in an awning provided it is ventilated. If I slept in the awning I wouldn't have it in there though, I would stick it outside and provide some sort of shelter for it. It is an easy matter to knock something up with a tarp, it's what camping is about for me.
helen&tony
Re: 3 way fridge
Post by helen&tony » Sat Jun 08, 2013 3:32 am
Yes, that's what I had planned, an old toilet tent cut right down, and a bit of a gap round the bottom, and a vent added to the top.
