Rear power point how do I hook it up to the leisure battery
richking
Post by richking » Mon May 06, 2013 8:55 pm
I've got the battery and all the couplings and fitted most of it in but i dont know where the wires from the rear power socket go to if they are in there at all ive tried looking at the diagram but its all japanese to me any ideas would be great thanks in advance.
Re: Rear power point how do I hook it up to the leisure batt
Post by g8dhe » Mon May 06, 2013 9:28 pm
The cigar lighter sockets are all fed from this fuse;
This also feeds several other things as well of course, including the radio switched supply.
Its normal procedure to connect these fuses to the L/B as well;
ImageThis is all the permanent feed circuits, radio et al.
ImageBlinds Front
ImageBlinds rear.
The normal way of connecting these to the L/B;
Remove the fuse and insert fuse into the fuse carriers for the L/B,
pickup the lower fuse connection to feed from the L/B fuse carrier.
This way a circuit can be rapidly switched back if ever necessary, also its very neat, and saves trying to intercept the feeds on the rear of the original fuse carrier, which is very fiddly !
