petrol smell
pantechnicon
petrol smell
Post by pantechnicon » Wed May 01, 2013 11:41 am
After an intermittent but strong smell of petrol in my V6 I had the filler neck hose changed which was cracked due to years of being encased in mud. Although this strong smell has now gone there is on occasion a slight whiff of . I have had it rechecked by the garage but they cannot find anything wrong. Any ideas folks ?
Pantechnicon
Re: petrol smell
Post by Simon Jones » Wed May 01, 2013 1:54 pm
Welcome to the forum :). Are you able to pinpoint roughly where the smell is worst? When I remove my filler cap, I get a rush of air out which suggests its under pressure rather than vacuum. A leak somewhere in the vapour control pipework could be the problem. Try taking the cap of after a run & see if you get the same rush of air coming out.
cheffy34
Re: petrol smell
Post by cheffy34 » Sat May 04, 2013 7:34 am
Nope had the odd occasional wiff for years in mine gave up trying to find it! quite nice actually reminds me of my youth :roll:
Re: petrol smell
Post by g8dhe » Sat May 04, 2013 8:57 am
Nothing from ours, however agree with Simon its under pressure!
Might be worth perusing the piping diagrams and looking at the possible joints etc.
pantechnicon
Re: petrol smell
Post by pantechnicon » Wed May 08, 2013 10:57 am
Simon Jones wrote:Welcome to the forum :). Are you able to pinpoint roughly where the smell is worst? When I remove my filler cap, I get a rush of air out which suggests its under pressure rather than vacuum. A leak somewhere in the vapour control pipework could be the problem. Try taking the cap of after a run & see if you get the same rush of air coming out.
Simon
Thanks for reply. The few occasions I get the smell it I can smell petrol whilst driving & slight smell by petrol cap. There is a slight rush of air on undoing the cap but will continue to monitor this area as a line of enquiry
over several trips to prove that I am not imagining things & am not totally paranoid !
Julian
pantechnicon
Re: petrol smell
Post by pantechnicon » Wed May 08, 2013 11:03 am
g8dhe wrote:Nothing from ours, however agree with Simon its under pressure!
Cheers for suggestion & link to piping diagram. Will explore the filler cap vacuum idea first as suggested by Simon, & failing that will consider looking at the joints.
Julian
