tv aerial
Moderator: Muzorewa
- Bongonaut
tv aerial
Hi wondered if anyone can tell me which is the best type of aerial to get for tv. many thanks Baz and Helen
Should have wrote the tv is for the bongo.
- mikexgough
Re: tv aerial
I use this one http://www.avtex.co.uk/antenna/sth1000.html has a booster which connects to your 12v too....
Others find that Caravan pole type aerials work well....
- Simon Jones
Re: tv aerial
Also got the Avtex and it's a good bit of kit for the size.
Re: tv aerial
Ive seen the avtex in use.......excellent
Ive also seen this one,and as a result its now the one I use.
Also excellent,and much cheaper and no screws/brackets reqd,the base is a very powerfull magnet
http://www.maplin.co.uk/magmount-dvb-t-aerial-217748
Brian
Brian
Re: tv aerial
I use the same one,I also use an angled plate that screws into one of the front holes in the roof,when the roof is raised it gives a bit more height.Bongoplod wrote:Ive seen the avtex in use.......excellent
Brian
It does have a powerful magnet.
The problem with reception depends on where the transmitter is and where you are.
Re: tv aerial
I've heard good reports of the Avtex, but I found the Maplins one to be useless, except in strong signal areas
- mine is hiding in my garage somewhere
- Simon Jones
Re: tv aerial
The Avtex has an amplifier so will always give better performance in weak signal areas than a non-amplified aerial.
- Bongonaut
Re: tv aerial
Hi thanks for the advice think I will go with the avetex, will let you know how it goes many thanks Baz and Helen
