Thanks Steve, I've just done that and yes, the opposite wheel spins the opposite direction so it's a standard diff as per the russian site...another fluid to check off my list of things to do
Looked like it needed the change to be honest.
How freely should the rear wheels spin is a question tho...If I spin them fast, I see the prop turning so I imagine they'll feel fairly heavy, but I wouldn't say they carry on spinning at all when I let go...feels uniform but more heavy than I was expecting. Reason I ask is my fuel consumption which I have meticulously logged since I purchased it in May last year was 28/31/27/28/29/28/28/31......then in November its suddenly gone up to 26/23/26/26/25/25/24/26/28/26 with the same daily usage.
Since November, I've changed discs and pads on the front, pads on the rear, and cleaned up the calipers a little when I did it..no sign of binding and I've driven say 2 miles and coasted to a stop and can still touch the discs..I'd say they were body temperature... I've adjusted the TPS inline with the manual..it was a little out...changed the oil and oil filter (5w/40), changed the air filter, fixed a broken EGR vacuum pipe to the air intake, checked the banjo filter, cleaned the tank filler cap (it was holding a vacuum in the tank)....It's been MOT'd with no problems in Feb
The handbrake works fine but I've not checked it as such..could that still be a potential binding problem even if it's working fine ?
Not sure if this is of any consequence, but it's my nearside that seems to more readily loss traction on wet grass..I've put that down to the conversion I have on that side but with the bongo jacked up with both wheels off the ground it did seem that the nearside wheel preferred to turn the prop than the opposite wheel....and when turning the offside wheel, the opposite wheel turned in preference to the prop.
I have it into 321Away tomorrow for a coolant change so will ask them to give it a feel..they've got a nice selection of bongos there so will know the difference between normal and not so normal I guess...
thanks,
Ant.
1995 M reg 2WD AFT in green/grey (and an Oakley Thermonuclear Protection decal for some reason!)
