Gearbox Not Changing
Scotty
Post by Scotty » Thu Aug 10, 2006 10:33 am
Jumped in my Bongo this morning and noticed that the gearbox didn't want to shift out of first until it had seemed to have warmed up. This took about 5 minutes. But if I pressed the Hold button it would shift.
Is this because the transmission oil is cool?
Has anyone else experienced this?
Gary Appleby
Post by Gary Appleby » Thu Aug 10, 2006 11:11 am
Can't say that I have, Nessie seems to be experiencing the same thing, stuck in park !
Look a few posts down !
GJA[/quote]
Post by Simon Jones » Thu Aug 10, 2006 1:45 pm
Scotty - a delay in changing to 4th gear is normal when the gearbox oil is still warming up. I seem to recall from other posts on the subject that it stays in 3rd to assist the heat up process. I've not experienced it probably since about March time when we last had a cold snap.
Scotty
Update
Post by Scotty » Thu Aug 10, 2006 6:06 pm
Drove my Bongo again this afternoon - again it took 5 minutes or so until it would shift. What I have noticed is that the rev counter seems to flick around as I drive along and when it appears to settle the gearbox shifts.
Scotty
Speed
Post by Scotty » Thu Aug 10, 2006 7:10 pm
Can anyone give me an idea what speeds the gearbox should be doing in each gear ?
Scotty
Should I ease off?
Post by Scotty » Thu Aug 10, 2006 7:13 pm
Should I ease off on the gas before the gearbox changes?
carliol
Post by carliol » Thu Aug 10, 2006 11:36 pm
Sounds to me as if your speed sensor is dodgy.
Scotty
Again
Post by Scotty » Fri Aug 11, 2006 4:32 pm
Again I got in my van started the journey home from work and it wouldn't shift out of first. Stopped in a layby - waited for it to warm up, shifted fine after that. Checked the autobox oil - seems to be clear in colour. I've heard from another post that its usually red or sometimes blue. Do you think an oil change will remedy this? Also notice that the rev counter needle seems to be behaving erratically. Where does this connect to the autobox - or do you think it mind be at the speedo back. I am not seeing any hold lights flashing - could it simply be a case of old oil or do you think its something to with a loose electrical connection?
This is really beginning to bother me - I have to wait everytime for my Bongo to warm up before I can drive it.
carliol
Post by carliol » Fri Aug 11, 2006 9:34 pm
Scotty -if I were you I would have a word with a gearbox/transmission specialist as the gearbox has various sensors and solenoids which can cause problems. It certainly is not normal for your gearbox to have to be warmed up to change gears other than from 4th gear to lockup. Others have spoken to and been helped by Dunnings Transmissions of Weymouth (tel:- 01305 783113) Usually your hold light will flash if you have a gearbox problem -the flashes can be interpreted to provide fault codes which will diagnose the problem. I also would have expected your ATF to be red -did you smell the fluid? If it smelled like burnt toast then it indicates problems. Just put "gearchange" in the search option on this site -there is quite a lot about gearboxes.
Scotty
Oil
Post by Scotty » Sat Aug 12, 2006 10:11 am
Can anyone tell me what grade oil I need to put in it
Post by Doone » Sat Aug 12, 2006 10:54 am
At the top of the forum there's a 'search' button. :) The gearbox oil is discussed on many threads including this one: http://www.igmaynard.co.uk/bongo/forum/ ... c2c12446a1
I think there's a factsheet in the members section.
Scotty
Solution???
Post by Scotty » Sun Aug 13, 2006 9:11 am
Took the speedo out yesterday and refitted it - the rev counter seems to be working now (its no longer flicking about erratically). The gearbox doesn't appear to need time to warm up before it shifts from 1st - 2nd as it did previously in my post. Does this make any sense to anyone - why would checking the connections on the speedo dials seem to resove the problem of the gearbox not shifting???
pippin
Post by pippin » Sun Aug 13, 2006 4:16 pm
Because the gearbox obviously needs to know the speed of the vehicle.
Scotty
Rev counter
Post by Scotty » Sun Aug 13, 2006 6:21 pm
So does the rev counter tell the gearbox when to shift or does the gearbox feed the rev counter. Could someone clarify the relationship?
Have searched the archives - has anyone experienced similar things when removing the speed dials etc
dandywarhol
Post by dandywarhol » Mon Aug 14, 2006 12:15 am
There's a sketch in the Members factsheet area of the inputs to the autobox....up to 11 in all, including vehicle speed and engine revs amongst others. The speedo is electronic and picks its sensor from the gearbox.
