Fitting Alloys, Help needed
Moderator: Ian
windywatson
Post by windywatson » Sat Apr 20, 2013 10:44 am
Just purchased some secondhand alloys and they need a spacer thing to fit onto the center boss to centre the wheel correctly. Unfortunatly they didn't come with them. What is the diameter of the boss that centres the wheel (hope this makes sense) please? I could fit without, but have read that you shouldn't rely on the wheel bolts to centre as this could lead to wheel balance problems & wooble etc.
Should I definatly get the spacer thing or can I risk fitting without?
Windy-Watson
2001 V6 Tin Top
mikeWalsall
Re: Fitting Alloys, Help needed
Post by mikeWalsall » Sat Apr 20, 2013 11:51 am
You can get spigot rings to make the bore (hole) in the middle of the wheel smaller .. but not the other way round.
http://www.wheelfitment.net/mazda
IE:- the bore of the Bongo is 67.1mm if the bore of your new wheels are larger, then spigot rings(bore reducers) should be available on eBay..
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
BUT .. if the bore on your new wheels are less than 67.1mm .. you have a problem ..
As I found out when refurbishing 5 Lexus rims .. to find the 60.1mm was to small to fit on the hubs ..
http://www.wheelfitment.net/lexus
windywatson
Post by windywatson » Sat Apr 20, 2013 1:12 pm
Cheers, just the advise needed. Fortunately the holes in the new wheels are larger. Now that you've given me the spigot size I can get what I need off e bay.
Cheers.
Windy-Watson
2001 V6 Tin Top
Return to “Pimp My Bongo”
