Knocking noise
markov1723
Knocking noise
Post by markov1723 » Fri Apr 19, 2013 2:13 pm
Im getting a knocking noise from the passenger front side whenever i go over a bump, even a tiny one. Does this sound iffy? Have had a look and cant see anything untoward, but im no expert.
Could it be related to a weird feeling when im on full right lock, where there is a much more dull noise like something catching rubber/plastic or could this be bongo moles?
Recent MOT pass and no mention of any issue/advisory stuff other than the usual kind of things Bongos always have ;-)
MarcT77
Re: Knocking noise
Post by MarcT77 » Fri Apr 19, 2013 2:42 pm
Sounds like drop-links to me,jack the wheel off the ground and look for movement side to side and up and down
and also check to see the 19mm nut is tightened up correctly,you can see this behind the wheel from the
wheel well without jacking it up.
markov1723
Re: Knocking noise
Post by markov1723 » Fri Apr 19, 2013 2:45 pm
Thanks Marc, will do that tonight.. well later. not in the dark, yknow ;)
Hanksy
Re: Knocking noise
Post by Hanksy » Fri Apr 19, 2013 2:50 pm
i had this not so long ago i changed droplinks and roll bar bushes, easy job (if nuts are not seized) now drives lovely :)
Re: Knocking noise
Post by mikeonb4c » Fri Apr 19, 2013 3:02 pm
Is it 4wd? Also consider CVs if so.
Driver+Passengers
Re: Knocking noise
Post by Driver+Passengers » Fri Apr 19, 2013 3:13 pm
MarcT77 wrote:... and also check to see the 19mm nut is tightened up correctly ...
+1 as a sanity check, before you start replacing parts. This got me.
Image Image
markov1723
Re: Knocking noise
Post by markov1723 » Fri Apr 19, 2013 3:15 pm
mikeonb4c wrote:Is it 4wd? Also consider CVs if so.
Yep 4WD
Lost on the CV's IDs though
Re: Knocking noise
Post by mikeonb4c » Fri Apr 19, 2013 5:15 pm
Yep 4WD
Sorry, UJs, I was in a rush. Doh!
windywatson
Re: Knocking noise
Post by windywatson » Fri Apr 19, 2013 6:13 pm
Common to get knocking like this as the bongo does suffer from worn drop links. Easy fix and not to expensive, so start with that first. Loads of info on this site about checking & which replacements to buy. If it is drop links don't fall for the ones that are to cheap as you'll be replacing them again really soon.
Windy-Watson
2001 V6 Tin Top
Re: Knocking noise
Post by Northern Bongolow » Fri Apr 19, 2013 9:22 pm
