Flush fitting 240 v inlet
i have done a few caravans which haven't been any problem. The issue I have is the best position for the inlet. What would the best place to fit?
- Tribal Elder
Re: Flush fitting 240 v inlet
I installed my 240v inlet on drivers side half way between door & rear wheel arch. There is plenty of depth in this location between the outer skin and the internal facia panal. The best way to determine the location for you is to remove the internal facia and have a look to see where there is sufficiant depth to accomadate the type of inlet you have to fit.
Windy-Watson
2001 V6 Tin Top
2001 V6 Tin Top
thanks will do - hoping to stay clear of fuel cap
- The Great Pretender
Under the bonnet, it stops a numpty like me from driving away with it connected.......
To infinity and beyond
Now there's a thought - best get a lead that elasticated lol
Have the panel off ready for the wheel arch to be repaired. I will probably fit in a similar position - how did you manage to cut out the hole?
- Simon Jones
Mine's fitted half way along the drivers side.
This is the best tool to use as it does not distort the panel at all:
http://www.machinemart.co.uk/shop/produ ... al-nibbler
Quite a bit of kit - have one on order
