I have no flashers
alan
I have no flashers
Post by alan » Thu Apr 18, 2013 7:52 pm
seem to have lost all indicator and hazzards light think it might be a fuse but which one plase #-o #-o
take it easy drive a bongo
Re: nhave no flashers
Post by g8dhe » Thu Apr 18, 2013 8:05 pm
Bongo Wiring Manuals are on line here http://www.g8dhe.net/bwm/
But the fuses will be;
alan
Post by alan » Thu Apr 18, 2013 8:06 pm
g8dhe wrote:Bongo Wiring Manuals are on line here http://www.g8dhe.net/bwm/
thank you
jaylee
Post by jaylee » Thu Apr 18, 2013 8:14 pm
The one highlighted is for the hazards... The 10amp red fuse on the row below, 3rd from the left is for the indicators.
alan
Re: I have no flashers
Post by alan » Fri Apr 19, 2013 5:01 pm
#-o #-o tryed put new fuse in but there just blowing as i puting them in hlep want next
Driver+Passengers
Post by Driver+Passengers » Fri Apr 19, 2013 5:05 pm
Have you got a multimeter? You may not need one but it might be an easier fix if you do. You can get one <£10 if there's a Maplin nearby or borrow off a neighbour.
Image Image
alan
Post by alan » Fri Apr 19, 2013 5:08 pm
Driver+Passengers wrote:Have you got a multimeter? You may not need one but it might be an easier fix if you do. You can get one <£10 if there's a Maplin nearby or borrow off a neighbour.
yeh loks like iam going to have to fine one or buy one but do the wires goi thought he door ??????? is it time to have a look at the door loom
Driver+Passengers
Post by Driver+Passengers » Fri Apr 19, 2013 5:13 pm
I can't imagine why they would.
Which fuse is blowing? Both of those mentioned above? You've probably got a short to ground.
I'm not up to speed with the light clusters, but if you can get the connectors removed from the indicator bulb holders and still blow a fuse, you can discount bulb holders and start looking at the wiring. If you've identified the right connectors, then you can start following whatever exposed wiring there might be.
Just an idea - not the 'right way' to go about diagnosing necessarily, but it's where I'd maybe start if I was faced with the same.
Image Image
Hanksy
Post by Hanksy » Fri Apr 19, 2013 8:17 pm
alan wrote:seem to have lost all indicator and hazzards light think it might be a fuse but which one plase #-o #-o
make sure you are not blinking at the same rate as the lights :lol: :lol: :lol:
the laird
Post by the laird » Fri Apr 19, 2013 8:40 pm
Take all bulbs out ,2 put indicators on and refit bulbs one at a time then see when it blows with which bulb done it,just a quick wy o pinpoint source then check those wires,hope this helps a bit
jaylee
Post by jaylee » Sat Apr 20, 2013 7:15 am
Do you have towing electrics fitted??
alan
Post by alan » Sat Apr 20, 2013 9:28 am
jaylee wrote:Do you have towing electrics fitted??
yes
alan
Post by alan » Sat Apr 20, 2013 11:40 am
yes
thank you for the pionters truned out to be tow bar wiring all soted cheers
