Post
by Northern Bongolow » Sun Apr 14, 2013 12:10 am
if its a diesel check the temp sender connection, this is at the top front of the head on the drivers side and has a single wire to it, this loops over the cam cover from the nearside harness, sometimes its tight and pulls on the top of the sender making a bad connection, remove and clean up.
or it could be that someone has messed with the screws on the rear of the guage cluster that hold the gauge in place, if these are over tightened they can affect the connections to the gauge as these screws take the electrical connections from the circuit print layer to the gauge itself via the screws. dont over tighten them though, just nip them, they are screwed into posts that have the gauge wires soldered to them, if over tightened these posts can spin and wind the wires round them until they break.
check the plugs into the clocks themselves, 2 of them, could be the supply voltage is altering, is your battery and alternator ok. if yes try the bolt on earth that is straight above the throttle peddle, its on the dash support bar/bracket, 10mm bolt.
check the main engine and gearbox earths, and the battery connections are clean and tight, including the battery earth to the body.
