I have found 2 problems (wehheey) and made 1 problem (booo) today and could do with some advice...
1. My 95 diesel auto 2wd has been rough to start from cold the last few weeks...it throws out a bit of black smoke and misses for about 20-30 seconds before idling normal and clean so I thought I'd take a look at the glow plugs today. Having pulled back the bracket with the relays on, I found the the second glow plug from the left is no longer attached to the rail..the top thread is sheered off. I'm hoping that's the cause so would like to replace it..having not done this before I was hoping I could just remove the relay bracket but not sure what the easiest way to remove that is...lots of hardened vacuum pipes I'm not sure will come off (see point 3!). Is removal of the top engine cover the way to go or should I attempt to disconnect sufficient pipes from the relays to get the whole 'stay'/bracket out of the way ?
2. With some further detective work I also found this....
I thought maybe EGR related but having read the glow plug factsheet now think it's one of the things that's supposed to switch the glow plugs off when being driven..Anyone know what this is called and where I might get one ?
3. Now for the problem I created...thought I'd try to pull the vacuum pipe off to get a closer look at that green valve and the other end then thing snapped straight off the air intake hose that goes round the back of the engine to the turbo.. it's the nipple labelled 1375/93-5104 in the middle of this diagram.. http://lushprojects.com/bongopartsmk2/c ... mgno=.html
I think I first option here is to try gluing it back on to the air intake and getting some new lengths of 'supple' vacuum pipe to refit unless anyone has any other suggestions..
thanks,
Ant.
