Page 1 of 3
Reverse light bulb
Posted: Sat Apr 06, 2013 3:59 pm
by Tidmo
Ordered myself some fancy 50 led reverse light bulbs. Went to fit them this morning. Original bulb is push fitting rather than the bayonet I assumed. Doh
Can anyone tell me what type I'm after now? I.e. 501 382 etc
Re: Reverse light bulb
Posted: Sat Apr 06, 2013 4:27 pm
by the laird
Can't you return bulbs? What n where did you get them ,any pics to see if we could shift them for you?
Posted: Sat Apr 06, 2013 7:07 pm
by mikeWalsall
Japanese style LED bulbs are quite rare and expensive .. and not really brighter than the cheaper Tungsten 21watt ..
http://www.ebay.co.uk/itm/EUFAB-48-SMD- ... 51a4b74a62
Posted: Sat Apr 06, 2013 8:15 pm
by David Edwards
I got mine off evil bay and they are superb to be fair.
Posted: Sat Apr 06, 2013 8:25 pm
by mikeWalsall
Bayonet fitting (easy to get) ... or cap less bulbs (some what harder to get) ..??
Posted: Sat Apr 06, 2013 8:27 pm
by jaylee
David Edwards wrote:I got mine off evil bay and they are superb to be fair.
I thought mine weren't bad either.....
They were something like this on mine.
Paul, for the life of me i can't remember if you have the new shape or not..? Though i spent a fair bit of time crawling over it.
Hows Friday looking?
Posted: Sat Apr 06, 2013 8:30 pm
by mikeWalsall
The above pic is the bayonet style and quite easy ..cheapish to source ... but not so the big cap less bulbs as used on many Japanese cars and motor bikes,
Posted: Sat Apr 06, 2013 8:46 pm
by Titan1995
I was given some 382 type led bulbs.....these come with a spotlamp type lens.
Absolutely fantastic...as to the origin....would need to speak to The Laird on here.
Posted: Sat Apr 06, 2013 10:50 pm
by lancyman
I just tried some of the led ones similar to
Jaylees ones. They didn't fit properly and ended up
Not working. Put some new filament ones in, instead.
Posted: Sat Apr 06, 2013 10:59 pm
by jaylee
lancyman wrote:I just tried some of the led ones similar to
There are actually two types of bulb, one is "off set" with the tabs at the base... The ones in the picture i posted ignore...
Bongo bulbs at the rear are off set..
Posted: Sat Apr 06, 2013 11:02 pm
by the laird
Hi guys I've used eBay,reverse bulbs item no 130815871489
7w Cree q5wedge led bulbs
Led ba 153
This is the ones Titan fitted hope this helps
Posted: Sun Apr 07, 2013 10:42 am
by Tidmo
Thanks for all your replies. The ones I have are 190810094295 on eBay.
Even after 2 years on here I can post photos
If anyone wants them then just get in touch.
I'm after capless type but not paying £20 for a pair!
Jaylee, ill text you mate.
Posted: Sun Apr 07, 2013 11:00 am
by Tidmo
Why has this been moved from tech to pimp?
Posted: Sun Apr 07, 2013 11:33 am
by jaylee
Anything to do with LED queries i think is classed as a pimp...!
Posted: Wed Apr 10, 2013 8:45 pm
by Titan1995
Tidmo wrote:Ordered myself some fancy 50 led reverse light bulbs. Went to fit them this morning. Original bulb is push fitting rather than the bayonet I assumed. Doh
All bulbs have a general model type:-
501,286,380,380,410,472 That sort of thing.
The bulb you want had a 382 designator. That would be 21W single post bayonet if a normal tungsten bulb.
Talk to The Laird..........he gave me a couple of 382 equivalent bulbs that are superb.
