Reverse light bulb
Moderator: Ian
Reverse light bulb
Ordered myself some fancy 50 led reverse light bulbs. Went to fit them this morning. Original bulb is push fitting rather than the bayonet I assumed. Doh
Can anyone tell me what type I'm after now? I.e. 501 382 etc
Pourquoi Pas?
Re: Reverse light bulb
Can't you return bulbs? What n where did you get them ,any pics to see if we could shift them for you?
- mikeWalsall
Japanese style LED bulbs are quite rare and expensive .. and not really brighter than the cheaper Tungsten 21watt ..
http://www.ebay.co.uk/itm/EUFAB-48-SMD- ... 51a4b74a62
David Edwards
I got mine off evil bay and they are superb to be fair.
- mikeWalsall
Bayonet fitting (easy to get) ... or cap less bulbs (some what harder to get) ..??
I thought mine weren't bad either.....David Edwards wrote:I got mine off evil bay and they are superb to be fair.
They were something like this on mine.
Paul, for the life of me i can't remember if you have the new shape or not..? Though i spent a fair bit of time crawling over it.
Hows Friday looking?
- mikeWalsall
The above pic is the bayonet style and quite easy ..cheapish to source ... but not so the big cap less bulbs as used on many Japanese cars and motor bikes,
I was given some 382 type led bulbs.....these come with a spotlamp type lens.
Absolutely fantastic...as to the origin....would need to speak to The Laird on here.
I just tried some of the led ones similar to
Jaylees ones. They didn't fit properly and ended up
Not working. Put some new filament ones in, instead.
There are actually two types of bulb, one is "off set" with the tabs at the base... The ones in the picture i posted ignore...lancyman wrote:I just tried some of the led ones similar to
Hi guys I've used eBay,reverse bulbs item no 130815871489
7w Cree q5wedge led bulbs
Led ba 153
This is the ones Titan fitted hope this helps
Led ba 153
Thanks for all your replies. The ones I have are 190810094295 on eBay.
Even after 2 years on here I can post photos
If anyone wants them then just get in touch.
I'm after capless type but not paying £20 for a pair!
Jaylee, ill text you mate.
Pourquoi Pas?
Anything to do with LED queries i think is classed as a pimp...!
Tidmo wrote:Ordered myself some fancy 50 led reverse light bulbs. Went to fit them this morning. Original bulb is push fitting rather than the bayonet I assumed. Doh
All bulbs have a general model type:-
501,286,380,380,410,472 That sort of thing.
The bulb you want had a 382 designator. That would be 21W single post bayonet if a normal tungsten bulb.
Talk to The Laird..........he gave me a couple of 382 equivalent bulbs that are superb.
