'HOLD' light flashing in dash..accidently put diesel in v6 p
ollyqw
Post by ollyqw » Thu Mar 28, 2013 6:45 pm
Hi......I accidently put diesel in my v6 petrol and travelled 100M before it conked out. Had the tank drained but no live connection for the pump now and HOLD light flashing....any ideas? Thanks...Olly.....also lpg lights not on
Re: 'HOLD' light flashing in dash..accidently put diesel in
Post by Simon Jones » Thu Mar 28, 2013 8:47 pm
Eeek. I expect the pump in the tank is knackered or the fine mesh filter is clogged up. Probably need to remove the pump for inspection and testing.
Also the main fuel filter will need to be changed. I think this sounds like a job for a Bongo specialist :(.
Post by Bob » Thu Mar 28, 2013 10:31 pm
Really bad luck mate.
Let us know roughly where you are and someone will recommend an expert.
ollyqw
Post by ollyqw » Fri Mar 29, 2013 12:51 am
Thanks for the advice...I'm in Bath
Post by Simon Jones » Fri Mar 29, 2013 11:33 am
Try Tom at Bell Hill Garage at Norton St Philip. They are Bongo experts although they tend to specialise in the diesel versions, but would probably be your best bet due to their location and as they can get any parts that may be required.
