Bongo garages in or near Windermere?
On our way to Windermere suddenly incurred probs with gear changeling/lack of power ,cut back on throttle and picks up again ,not fuel filter,have noticed when this happens bluey smoke out exhaust.egr? Can any suggest
Re: Bongo garages in or near Windermere?
The club database on Bongo Friendly garages give two near your location. One in Kendal and one in Flookbrough near Grange over Sands which is probably the one that Harry used to use.
Brunthwaite Garage, "Little Brunthwaite, Old Hutton", Kendal, Cumbria, LA8 0NN, tel:01539 723637,
W Keith & Son Ltd, "Keith Auto Repair, Moor Lane Garage, Moor Lane", Flookburgh, Cumbria, LA11 7LS, tel:01539 58259,
Good Luck
Tony
Good Luck
Tony
Cheers tony
What's their reputation like?
Where do we find bongo friendly garages on site.?
sounds like a fuel problem.
have you checked the banjo filter, ive had a few with clean looking banjo filters, but when you fish them out there is snotties hanging from the bottom blocking the flow. or swap the main filter,there are some very poor ones about.
or the old fault of the tank breather blocked. try it with the cap off. if this is the fault the main tank breather is blocked, this is attached to the chassis near the gearbox breather pipe chassis.
Search me, never used either of them. perhaps someone local will come on and tell you. Pixe and the moon lives very near Flookbrough. Hopefully it will be one of the simple remedies suggested by Ady.
Tony
Tony
Here http://www.igmaynard.co.uk/bongo/member ... #databasesthe laird wrote:Where do we find bongo friendly garages on site.?
Cheers guys for all posts printed off a copy from data base.bad news but,I've just changed the filter removed banjo bolt and screen all spotless,bled and started ran fine for a minute then a noise started from the injection pump! Can only describe as like a solenoid rattling as soon as this occurs the lack of power starts ,conclusion pump grubbed I think and it's never been on veg oil in its puff.hopefull it's covered under warranty I have (three years and the paperwork states mechanical pump covered )
- PixieAndTheMoon
The Laird,
Ady is a mechanical Guru so take his advise. Garage we personally trust if you cannot fix it is Camp Road Garage, Moor Lane, Flookburgh, LA11 7LS. They have no beards to stroke (as in this will cost you) and do a good job. Local lads.
Depending on where you are in Windermere they could be 30 to 10 miles away. Hope all is ok Friend. Please PM me if you need them they do pick up's.
Jo
Jo
Thanks jo taken on board
Guys just an update gonna struggle back home with bongo.it seems like the pump advance solenoid s
Went up in the air.phoned a friend of mine who owns lawson diesel in Edinburgh they do work for Ava etc he agrees with my diagnoses so he is going to test and overhaul the pump for me.if anyone wants seals etc for the bongo he's your man and will post out etc.thanks again for your posts just I panicked a bit with the Windermere trip
Regards the laird
Regards the laird
