Coolant Hose Sizes / Specs ?
- Bluespanner
Is there a list floating around anywhere of the coolant hose sizes used in the Diesel Bongo 2.5td 1996 onwards. I'm most intrested in the smaller bore hoses, header tank to top of radiator, front and rear heater hoses etc. Thanks
Re: Coolant Hose Sizes / Specs ?
Here it is for you. It has been in the seach area for quite some time. Complied by MissFixit.
Tony
Complete list of hoses, 17 in all on a diesel, numbers are drawing numbers, part numbers can be got from the drawings by clicking on the + symbol on the description on the left,
Main cooling system - http://www.lushprojects.com/bongopartsm ... mgno=.html
15-261 - bypass/recirc into top of thermostat
15-381 - bleed hose
15-186 - top hose/engine outlet to large metal pipe drivers side
15-183 - Large metal pipe drivers side to top of rad (inlet)
15-184 - bottom of rad/outlet passenger side to large metal pipe passy side
15-185 - passy side large metal pipe to bottom of thermostat
15-227 - top of rad to header/expansion tank
15-188 - expansion/header tank to heater return pipe
Most of front & rear heater system - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-211 - drivers side heater pipe to front heater matrix
61-212 - front heater matrix to heater return pipe
61-214 - heater return pipe to thermostat
61-213 - outlet over starter on engine, drivers side to heater pipe
61-211A - drivers side heater supply pipe to rear heater matrix
Rear heater return - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-212C - rear heater matrix to return pipe behind engine
Another rear heater return - http://www.lushprojects.com/bongopartsm ... 1of02.html
61-213A - rear heater return pipe connector behind turbo under passy seat
Two turbo cooling hoses - http://www.lushprojects.com/bongopartsm ... mgno=.html
13-539A &
13-546 - turbo suppply & return hoses
Tony
15-381 - bleed hose
13-539A &
- Bluespanner
thanks Tony
