fuel light
DRob
fuel light
Post by DRob » Sat Feb 23, 2013 9:06 am
Is there one?
I am trying to get an idea of the mpg so want to run the tank as low as I can. In my cars I rely on the warning light and know I have ~50 miles to find some fuel. But this comes on when I am well into the red zone.
On the bongo I have just started touching the white block, but dont know if this is a 'think about getting some fuel' level or 'woah there, stop at the next garage boyo' event!
Any thoughts?
Dom
wonkanoby
Re: fuel light
Post by wonkanoby » Sat Feb 23, 2013 9:51 am
early one dont evan have a light
fill it up
drive a few hundred miles
fill it up again
longhaul8
Re: fuel light
Post by longhaul8 » Sat Feb 23, 2013 10:04 am
Or carry a can can of fuel just incase
DRob
Re: fuel light
Post by DRob » Sat Feb 23, 2013 10:29 am
Righto, looks like I'll be playing chicken with the fuel gauge!!!!
Cheers guys.
Re: fuel light
Post by haydn callow » Sat Feb 23, 2013 11:42 am
Why play chicken.....just fill it when it gets to a quarter......not a good idea to run it to low as you will start getting crud through the pipes
jaylee
Re: fuel light
Post by jaylee » Sat Feb 23, 2013 12:08 pm
Or sign up & study yer mpg on here...? http://www.fuelly.com/car/mazda/bongo
DRob
Re: fuel light
Post by DRob » Sat Feb 23, 2013 5:10 pm
I have always run my vehicles low to keep the crud out of the system.
Always running it low means the crud is being dragged through in small chunks, and the fuel filter should be able to manage it... I hope.
If you are forced to run low for some reason and there is a load of crud in the bottom that is suddenly dragged through in one big lump it can cause issues.
Does rely on cleaning or at least inspecting the filter though.
Just signed up to Fuelly, apparently my first tank brought 28.3 MPG. Gonna have to try and improve that I think.
daveblueozzie
Re: fuel light
Post by daveblueozzie » Sat Feb 23, 2013 6:30 pm
DRob wrote:I have always run my vehicles low to keep the crud out of the system.
Dont forget the banjo filter, if that blocks then you will have fuel starvation.
Lost without my Bongo.
Re: fuel light
Post by haydn callow » Sat Feb 23, 2013 7:30 pm
Each to his own !!
Re: fuel light
Post by Bob » Sat Feb 23, 2013 8:06 pm
Personaly I don't let the gauge go under 1/4. Twice in the last month we've been scrambled to family members in, or needing to get to hospital. Not the time to be thinking which garage is open.
Also gives you some slack if the queues are bad, no power, banking system down...
splitpin
Re: fuel light
Post by splitpin » Sat Feb 23, 2013 8:42 pm
Fuel warning lights were fitted from 98 on, my light comes on when fuel gauge needle is below white marker. Ihave done 25 miles after light came full on but don't know how much further it could go.
