speedo fails to operate and hold light flashes
Posted: Tue Aug 01, 2006 9:41 pm
by mikeherald
Hello, when starting off today after leaving the bongo for about an hour, then restarting, the speedo didnt work and the hold light flashed.
I drove home, and then switched off.I restarted and the hold light was off, and tried driving up road and speed ok.would the hold light operate if the speedo stuck?.Also it has had a electronic kph/mph unit fitted in past.
Posted: Tue Aug 01, 2006 10:04 pm
by pippin
Lots of previous posts on this subject so a search should reveal detailed info.
From memory it is probably due to a loose connection at the back of the speedometer where the wires to the converter chip have been connected.
Posted: Tue Aug 01, 2006 10:07 pm
by moonshine
I have had this same thing happen with mine, although it hasn't done it lately. The hold light doubles as a fault light, and it is flashing to indicate that you and I have a problem with the speed sensor which drives the speedo, or the converter chip. It could be just a dodgy connection.
Posted: Tue Aug 01, 2006 10:47 pm
by Bumbly1
In my case, it was the speed sensor, I did post the part number some time ago so a search should dig it out. It also put the gearbox in default mode.
Tom
Posted: Wed Aug 02, 2006 11:14 pm
by Chris P
I can believe the "dodgy connection".
My speedometer fails periodically, and a sharp tap above the display has always cured it so far...
Chris
Hold light etc.
Posted: Wed Aug 02, 2006 11:22 pm
by motorwizard
The gearbox gets a signal from the speedo. If the signal is faulty the hold light will flash and the hold will not lock in a gear. If you remove the instrument cluster on the printed circuit you will see (I think) where a screw connects the output from the speedo to the printed circuit which then goes to the gearbox ecu. There is an old thread for this as on my van the hold light flashed since I bought my van. In tracing the fault found that the screw was missing and so no signal from the speedo to gearbox. I have left the odometer reading in kilometers and changed the face so that I didnt modify the signal to the head which may affect the signal to the gearbox.
