Loss of woomph after changing seals..
Dr Fingers
Post by Dr Fingers » Fri Feb 01, 2013 12:57 pm
My regular Bongo garage has changed the seals on my diesel pump, and subsequently there is no real power under any sort of load, eg hills, open road acceleration.
Bongo struggles to reach 60mph on the open road. She seems to rev freely enough, starts fine, smooth tickover, but has lost 50% of actual 'go'.
He's done this job before, and is very 'Bongo-savvy', but admits to being stumped. Currently waiting for a replacement pump, but in the meantime can anyone suggest what may have gone adrift?
All help very welcome!
Derek
Driver+Passengers
Re: Loss of woomph after changing seals..
Post by Driver+Passengers » Fri Feb 01, 2013 1:41 pm
Is the little vacuum tube that goes from a nipple on the inlet manifold elbow to the top of the fuel pump connected?
Image Image
Post by teenmal » Fri Feb 01, 2013 1:53 pm
Hi Derek,did the mechanic remove the pump?,why are you needing a replacement pump. :?
Cheers.
Post by Simon Jones » Fri Feb 01, 2013 2:35 pm
If its been removed or disturbed then the pump may need to be re-timed.
Dr Fingers
Post by Dr Fingers » Fri Feb 01, 2013 4:21 pm
teenmal wrote:Hi Derek,did the mechanic remove the pump?,why are you needing a replacement pump. :?
Cheers.
I assume the pump was removed so that new seals could be fitted.
The seals were replaced because Bongo was very smokey (embarrassingly so) on cold start ups, but fine when warmed up. The diagnosis was that the pump seals were leaking diesel when cold, resulting in aforementioned smoke: as engine/pump warmed up, the old seals would have expanded and the leak would stop.
As far as I know, nothing else was done to the pump, just the fitting of the new seals..
Derek
jaylee
Post by jaylee » Fri Feb 01, 2013 11:28 pm
Dr Fingers wrote: Bongo struggles to reach 60mph on the open road. She seems to rev freely enough, starts fine, smooth tickover, but has lost 50% of actual 'go'.
Derek
:-k A wild guess from experience & could be totally wrong but worth a check for an easy fix....???
The big bore pipe coming up from the inter-cooler to the elbow on the front top of the engine may have dropped/come loose?? Not easy to see if it has dropped slightly..?!!
See here.. part U in the circle...? http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Going to pipe 13-246... http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Hope this helps...?!!
Dr Fingers
Post by Dr Fingers » Sat Feb 02, 2013 10:18 am
Hope this helps...?!![/quote]
Many thanks, have forwarded this to the garage.
Derek
321Away
Post by 321Away » Sat Feb 02, 2013 10:24 am
agree with jaylee, could be the charge inlet pipe slipped, but you can normally hear the air escaping when on boost?
The fuel pump timing is set with a woodruff key so it cant be set outside its working parameters, theres only a small degree of adjustment to allow for fine tuning, having said that i have seen a fuel pump that was fitted incorrectly, the garage assumed the key was located and bolted it all up, the bottom pulley was hower pushed forward and didnt run straight so it damaged the cambelt!
Take it back to the garage, sure they wont have a problem with looking it over.
Julian
Post by mikeonb4c » Sat Feb 02, 2013 10:25 am
No-ones mentioned the TPS yet. Any chance this could have been upset/disturbed?
Dr Fingers
Post by Dr Fingers » Tue Feb 05, 2013 12:57 pm
As an update.
Replacement pump fitted from breaker: that proved faulty as well, so my guy is off to S London to pick up another one.
He asked a local firm for a quote to rebuild the original..
£1000 + ???? :shock: :shock: :shock:
Derek
scanner
Post by scanner » Tue Feb 05, 2013 1:06 pm
Dr Fingers wrote:As an update.
Derek
Could changing the mechanic be cheaper? :wink:
Dr Fingers
Post by Dr Fingers » Tue Feb 05, 2013 1:17 pm
Which mechanic? My regular guy has been good as gold over the past year, done lots of good work at very fair prices.
It's the rebuild quote that has stunned us.
He wasn't pushing for the £1000 rebuild, quite the contrary, he said it was ludicrous, not an option, and as we speak he is driving up to London to find a breaker part that works.
Apparently pumps left on the shelf can dry out/seize up as there is no diesel in them to keep them lubricated, so he's going up there to take one directly off a broken bongo..
Derek
helen&tony
Post by helen&tony » Tue Feb 05, 2013 2:39 pm
Derek...
Search the Forum for pump rebuild, there's been a few posts, from memory, on rebuilt pumps...for a lot less than a bag o' sand! :shock: :shock:
scanner
Post by scanner » Tue Feb 05, 2013 2:53 pm
Dr Fingers wrote:Which mechanic? My regular guy has been good as gold over the past year, done lots of good work at very fair prices.
It just looked as if he might be getting a bit out of his depth here - if you had the oomph before he changed the seals, it has to be something he has or hasn't done that has lost it and whatever it is seems to have stumped him.
The fact that a different pump is exactly the same indicates (to me) that there is some common factor involved and a second opinion might reveal what he could possibly be missing.
wonkanoby
Post by wonkanoby » Tue Feb 05, 2013 4:20 pm
there are vacumn pipes go to the pump are you sure these were all put back right
