Post
by New Forest Terrier » Wed Jan 30, 2013 10:33 pm
Had a version of this problem before Christmas. It started when the Bongo refused to start in Lidls car park. The gear lever button that allows you to get it out of park was stuck and the Bongo, convinced it was in gear was doing absolutely nothing. RAC man turned up gave it a thump on the side of the gear lever which persuaded it that it was actually in park. The problem seemed solved but on getting home the key could not be removed.
The cause of this was that the ignition, park button on gear stick and and parking brake are linked via a cable. This is probably either displaced or damaged at the gear lever or ignition end. It is totally mechanical on my 95, cable pulls levers. If this is not pulling the correct bits Bongo will not start, thinking it is in gear rather than park or it will not allow the key out of the ignition.
To get at the gear lever end take of the center console and then you can see the underside of the gear lever. There are two cables, thick one on the passenger side for the gear change, thin one on the drivers side. This is the one to the ignition which is the cable causing all the trouble. It ends in two levers, the top one is connected to the button that releases the gear lever. Pull this lever and in my case normal service was restored, until it jammed again. To get better access there is a trianglar panel in the drivers footwell that can be pulled off to give a fuller view of the connections at the gear lever end.
Sorting the at cable will cure the problem. If the cable is damaged the Bongo runs fine without it, just no automatic handbrake in park.
In my case the cable was snagging somewhere along its length and the cure was a second hand cable as replacement. I also started using the spare Bongo ignition key as the original was very worn.
