Any help would be greatly appreciated. many thanks
interior strip light
hi fellow bongoers. my little strip light in the boot on the roof in the middle doesnt seem to be very bright. i replaced the bulb last summer and everything seem to be fine then after a couple of months it semt to be quite dull so i took off the strip light cover and took out the bulb and in doing so one of the two pins on one end dropped down slightly. (not on the actual bulb but on the fitting). i pushed then pin back up and checked the others and put in the bulb and bingo. not long after, maybe a week and it went dim again and a black lump (size of a marble) appeared in the bulb, but it still glows semmy bright. Could there be a bad connection to the fitting? is all the lights on one circuit? probably a good possibility that the bulb is dying again but what is causing it to go ??
Re: interior strip light
Sounds like the connection pin to the circuit board in the lamp fitting has broken from its soldered point...?junior wrote:Could there be a bad connection to the fitting?
An easy repair with a soldering iron..
The lamp is easily removed. Two screws hold it in place, (They can be seen when the lens/diffuser is removed) then just unclip the white connector.
It's a long time since i repaired mine, but i think there is a backing plate that unscrews to reveal the gubbins...
junior wrote:hi fellow bongoers. my little strip light in the boot on the roof in the middle doesnt seem to be very bright. i replaced the bulb last summer and everything seem to be fine then after a couple of months it semt to be quite dull so i took off the strip light cover and took out the bulb and in doing so one of the two pins on one end dropped down slightly. (not on the actual bulb but on the fitting). i pushed then pin back up and checked the others and put in the bulb and bingo. not long after, maybe a week and it went dim again and a black lump (size of a marble) appeared in the bulb, but it still glows semmy bright. Could there be a bad connection to the fitting? is all the lights on one circuit? probably a good possibility that the bulb is dying again but what is causing it to go ??
i will have a closer look and have a go at repairing it. many thanks
Mine was the same, just a dry joint on the bulb connections, resoldered it and all OK
