Mazda Bongo Exhaust 2.5TD Short Pipe (Winter Pack System)
This part of the exhaust needs replacing but the part came with no bolts or gaskets and the current ones are completely corroded.I've came across the 4 bolts as described below..can anyone tell me if these are what I'm looking for and i/ll also need 2 gaskets when replacing?
Cheers Del
Mazda Bongo Friendee & Ford Freda Exhaust Winter Pack Bolt Kit. Fits all models 2.0ltr Petrol FE-E, 2.5ltr V6 Petrol J5-DE & 2.5 Turbo Diesel WL-T from 1995-2003. If fitted with winter pack.
Includes: 4 long bolts, 4 nuts and 8 washers.
WHAT IS A WINTER PACK?
If Your Mazda Bongo has a black switch with a picture on an engine with heat lines rising from it by the drivers right knee, Then you have a winter pack!
If your Mazda Bongo has a 4 piece exhaust system these are the bolts that join the two straight pipes together fixing then to the exhaust valve. These bolts are very often completely corroded and need to be cut off when replacing the adjacent exhaust pipes.
The two parts they join together are below this listing:-
MAZDA BONGO EXHAUST 2.5TD LONG FRONT PIPE (WINTER PACK SYSTEM)
MAZDA BONGO EXHAUST 2.5TD SHORT PIPE (WINTER PACK SYSTEM)
Exhaust short pipe bolts
Re: Exhaust short pipe bolts
they sound right, you may get the gaskets at most good exhaust fitters, or mazda will do them, usually in a few days.
