Rear blowers not blowing
bongobridge
Post by bongobridge » Sat Jan 12, 2013 2:36 pm
Hi Folks,
Need some advice :?
The rear blowers have now stopped blowing ,checked fuses ( I think ) and have pressed the button which sends control to the back , on the control panel all the lights are on but no luck , the front heaters are fine #-o
Any ideas????
Nick & Jen
[color=#FF8000]life's a beach, then you fry[/color]
jaylee
Re: Rear blowers not blowing
Post by jaylee » Sat Jan 12, 2013 2:39 pm
Is this the manual heater controls with the slider control??
bongobridge
Post by bongobridge » Sat Jan 12, 2013 2:47 pm
Yes in the back drivers side under window ( no conversion )
Nick & Jen
philpdr
Post by philpdr » Sat Jan 12, 2013 11:01 pm
The fan in the back of mine only works with the front fan on as well.
Post by Simon Jones » Sun Jan 13, 2013 12:26 am
Try fuse 15 in the fusebox under the bonnet: http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
Terri & colin
Post by Terri & colin » Sun Jan 13, 2013 12:53 am
Mines not working... I'm thinking that my control is behind the fridge.. Coz my van is dodgy lol I'm going to see if I can see anything in the morning and check the fuse.
wonkanoby
Post by wonkanoby » Sun Jan 13, 2013 7:43 am
are you sure you evan have one as many convertors rip it out
bongobridge
Post by bongobridge » Sun Jan 13, 2013 11:35 am
Thanks Simon but fuses are ok #-o
Nick & Jen
Titan1995
Post by Titan1995 » Sun Jan 13, 2013 11:39 am
Hopefully something simple is the problem. However, if the fan motor has died [unlikely], I have a spare one at home.
jaylee
Post by jaylee » Mon Jan 14, 2013 12:02 am
You could try looking to see if nothing has dropped down through the intake vent & jamming the fan...? http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Post by g8dhe » Mon Jan 14, 2013 12:12 am
The circuit is below, there is one relay controlling the rear Fan much as in the front but only 3positions of speed and Off, the relay is down with he rest of the gubbins;
jaylee
Post by jaylee » Mon Jan 14, 2013 12:39 am
g8dhe wrote:The circuit is below, there is one relay controlling the rear Fan much as in the front but only 3positions of speed and Off, the relay is down with he rest of the gubbins;
Geoff, Doesn't the rear heater have a "resistor pack" set up?? :idea: :arrow:
Post by g8dhe » Mon Jan 14, 2013 10:40 am
Yes hence the 3 speeds, they could have popped, but the reason for popping is normally corroded motor bearings, which are a lot less likely in the rear than the front, but yes still a factor to consider.
321Away
Post by 321Away » Mon Jan 14, 2013 2:25 pm
think Jaylee is questioning if an object fell in and stopped the fan blades it could simulate a fan seizure and pop the reisitor pack?
Only problems i've encountered with rear fans were usually relay related as geoff already mentions
Julian
Post by g8dhe » Mon Jan 14, 2013 5:24 pm
Yes that does make sense Julian!
