Steering - pumping action!
LS&A
Post by LS&A » Sun Jan 06, 2013 5:33 pm
Difficult to explain so please bear with me. Although this doesn't cause me any issues other than slight irritation... When I steer turn the steering wheel to corner then press the accelerator coming out of the corner the steering feels like its pumping or slowly cavitating. Any ideas?
Re: Steering - pumping action!
Post by Northern Bongolow » Sun Jan 06, 2013 5:50 pm
low fluid maybe, check its up to the line.
if its ok check the colour of the fluid it should be bright red and clean.
rack on its way out.
pump on its way out.
the laird
Post by the laird » Sun Jan 06, 2013 6:56 pm
Make sure the steering column u/j is not partially seized,I would check this out ,,can be misleading if it's sticky
Driver+Passengers
Post by Driver+Passengers » Sun Jan 06, 2013 6:58 pm
A hard acceleration at near full lock and mine will feel like the power steering conks out for a second or two. No pumping sensation, and I don't know what you mean by cavitation, but thought I'd mention this as I think others have experienced the same.
Image Image
Post by teenmal » Sun Jan 06, 2013 7:42 pm
H,is it a 4WD vehicle.
LS&A
Post by LS&A » Sun Jan 06, 2013 9:23 pm
Yes it's 4wd. Thanks all for ideas.
