anyone used universal style of air filter ,to make space ??
chipvan
Post by chipvan » Tue Jan 01, 2013 5:06 pm
anyone used this type of filter?
http://www.knfilters.co.uk/search/produ ... od=RU-1200
to try and get rid of the dustbin sized filter box on bongos.?
would it work ok?
thanks
wonkanoby
Re: anyone used universal style of air filter ,do make space
Post by wonkanoby » Tue Jan 01, 2013 5:11 pm
why not just use the k and n fits in the bin
wonkanoby
Post by wonkanoby » Tue Jan 01, 2013 5:18 pm
chipvan
Post by chipvan » Tue Jan 01, 2013 5:18 pm
the laird
Post by the laird » Tue Jan 01, 2013 5:25 pm
Yeah it will work ok but do you know how much noise will be increased due to the induction level not being suppressed by theDUSTBIN
chipvan
Re: anyone used universal style of air filter ,to make space
Post by chipvan » Tue Jan 01, 2013 5:27 pm
didnt think of that!..
Post by Simon Jones » Tue Jan 01, 2013 5:41 pm
The other important thing is that you get practically no air flow if you just fitted it directly in place of the current air filter box. If you could use all the existing ducting from the front of the van and then fit an inline filter, then you may be ok. As a diesel has no throttle to adjust the air flow into the engine it needs to be able to breathe very well which is partly why the standard filter element is so big with a large surface area.
chipvan
Post by chipvan » Tue Jan 01, 2013 5:57 pm
Thanks for the advise,will leave that idea!..
