Using the LB as a starter battery
TerryG
Post by TerryG » Mon Dec 17, 2012 1:03 pm
What's the best way to use the leisure battery if the starter battery is flat and a Willinton kit is fitted?
Could you just carry a suitable length of cable with a croc clip at either end to bridge the positive terminals (after disconnecting the LB positive lead)?
'Enjoy every sandwich'
Re: Using the LB as a starter battery
Post by Simon Jones » Mon Dec 17, 2012 1:14 pm
Assuming the LB is earthed to the chassis with a proper suitably rated cable, then you could use a single jump lead to link the two positve terminals together. I've seen some 'professional' conversions that use 13A mains cable as the earth connection on a leisure battery, so if there's any doubt, use both jump leads.
Post by g8dhe » Mon Dec 17, 2012 1:15 pm
Use just a normal jumper cable to connect the batteries, you could just use the +ve, but don't do it to often!
TerryG
Post by TerryG » Mon Dec 17, 2012 3:46 pm
Great - thanks chaps!
Post by mikeonb4c » Mon Dec 17, 2012 4:20 pm
Have a read of old threads. Not really a good idea to use LB as SB
TerryG
Post by TerryG » Mon Dec 17, 2012 5:19 pm
mikeonb4c wrote:Have a read of old threads. Not really a good idea to use LB as SB
I'm sure you're right - I was just thinking about emergency situations
Post by mikeonb4c » Mon Dec 17, 2012 6:08 pm
Yea i had to do it once when i left my sidelights on. It was ok as i had a brand new 135ah Energy Bull and a car that started in a flick. But even then i could tell the LB lacked the cranking amps and would have been better left for a bit to transfer its energy to the SB before i turned the starter. And if i'd had a lower power LB, would it have coped?
philpdr
Post by philpdr » Mon Dec 17, 2012 6:37 pm
Done it with my 110ah.no problem
westonwarrior
Post by westonwarrior » Mon Dec 17, 2012 9:00 pm
http://igmaynard.co.uk/bongo/forum/view ... it=battery
not recomended but it worked for me
Post by Simon Jones » Mon Dec 17, 2012 9:12 pm
Depends on the type of LB you have. I've got an Elecsol Carbon battery like this which is dual purpose:
http://www.elecsolbatteries.com/product ... l-100.html
Dual purpose, engine start and deep cycle battery. Benefits a range of uses including Boats, Caravans, Motorhomes and engine starting.
Specifications:
Deep cycle and engine start.
Dimensions (LxWxH): 278 x 175 x 190 mm.
Weight: 19.5kg.
Cycle life: 1000 cycles to 80%dod.
Guarantee: full 5 year, maintenence free.
Post by mikeonb4c » Mon Dec 17, 2012 9:39 pm
Simon Jones wrote:Depends on the type of LB you have. I've got an Elecsol Carbon battery like this which is dual purpose:
Specifications:
Weight: 19.5kg.
This is all true and my energy bull can cope fine @ 135ah, but still not to be done casually, would be my advice ;-)
