water pump - getting it to work with engine off -preheater?
Paulinwales
Post by Paulinwales » Sun Dec 09, 2012 2:55 pm
I have a water pre-heater that is thermostatically driven - it works but the thermostat cuts out due as the pump on it must be underrated. I Have been using it for a year, but it's a little slow at heating as it is turned off half the time, and also when it does it stops the pump.
I wonder if there is an easy way to activate the bongo water pump with the engine been off to assist the flow and solve the problem? Anybody been fiddling with the wires in that area?
rgds Paul
Re: water pump - getting it to work with engine off -preheat
Post by g8dhe » Sun Dec 09, 2012 3:05 pm
The water pump is mechanically driven by the engine, no wires involved .....
Post by Simon Jones » Sun Dec 09, 2012 3:11 pm
Sounds like you need a better circulation pump. What type have you got currently? This type of thing looks quite good:
http://www.ebay.co.uk/itm/Water-Pump-fo ... 51a20564a8
Paulinwales
Post by Paulinwales » Sun Dec 09, 2012 3:26 pm
Doh, thanks guys tgat was embaring. Think i might just turn it on earlier as i don't want to spend any dosh
Thanks paul
