Tailgate rubber seal
Bongoolagong
Post by Bongoolagong » Wed Nov 14, 2012 10:52 am
The rubber seal around the rear door has perished causing the rear door to rattle. I've tried adjusting the catch but is still rattling annoyingly! #-o
Anyone know where I can get a replacement? Cheers Bongonauts =D>
Re: Tailgate rubber seal
Post by Northern Bongolow » Wed Nov 14, 2012 11:45 am
search the net for bongobits4u2012. or 200bhpcars. give them a call.
Post by rita » Wed Nov 14, 2012 12:23 pm
wonkanoby
Post by wonkanoby » Wed Nov 14, 2012 12:49 pm
are you sure your moving catch the right way
moving it out caused it to latch right as by pushing it in it was only on the emergecy first part of the catch
Post by Simon Jones » Wed Nov 14, 2012 1:33 pm
Be wary that any 2nd hand rubber seal (which could be upto 17 or 18 years old) is not going to be in peak condition. May be worth checking for other sources of rattle as well. Have you got both the corner bump stops present?
Post by Northern Bongolow » Wed Nov 14, 2012 2:54 pm
also winding the spare wheel up too tight pulls the floor down, loosen the wheel or remove it then try. #-o
Bongoolagong
Post by Bongoolagong » Wed Nov 14, 2012 7:36 pm
Many many thanks for your help and advice bongonauts this is great knowing I'm not alone out there!! :wink: Stand by for an update :D
Post by Northern Bongolow » Wed Nov 14, 2012 10:35 pm
Northern Bongolow wrote:also winding the spare wheel up too tight pulls the floor down, loosen the wheel or remove it then try. #-o
no it doesnt it pushes the catch and rear floor up. (sorry). anyway you get the idea.
