Knocking from the rear.............
Bongo??
Post by Bongo?? » Wed Nov 07, 2012 9:52 pm
Hello all.
I`ve just had all my anti-roll bar drop links,and D bush`s replaced with new brackets,front and rear.
The trouble is the rear end still knocks on rough surfaces.
Is there anything else at the rear that is known to knock??
And i am referring to the "rear"of the van!!!!!!!!!!!!!!!!!!!!!!! :roll: :roll: :roll: :wink:
Year 2000 V6
Driver+Passengers
Re: Knocking from the rear.............
Post by Driver+Passengers » Wed Nov 07, 2012 10:04 pm
If you don't have a spare wheel underneath, then the bracket that would hold it in place can knock around.
Give the exhaust a good waggle and jack up each wheel and give them a good waggle, too.
Image Image
Post by Northern Bongolow » Wed Nov 07, 2012 11:39 pm
next easiest to check would be the shocker mounting rubbers and shocks themselves.
