Bogmonster40
Post
by Bogmonster40 » Sat Nov 03, 2012 10:58 pm
I have this as a rear light above sliding door. I'd like to know is this standard that I can buy from club shop (on their return) or is this something the previous owner put in ??
The bulb is gone now so in need so something that will shine a light on my girls so I can see what they are up to
http://i1110.photobucket.com/albums/h45 ... 2071-1.jpg
V6 2.5i Tintop Aero Petrol/LPG
MarcT77
Post
by MarcT77 » Sun Nov 04, 2012 12:02 am
Tap your cursor on the IMG link on the photobucket photo and you should see it change to
'copied' then 'paste' in to your post here.... bingo job done,always use the Preview before posting to check
you got it right....
Bogmonster40
Post
by Bogmonster40 » Sun Nov 04, 2012 10:39 am
Nice one Simon, can anyone recommend anything brighter like an LED alternative ??
Post
by Simon Jones » Sun Nov 04, 2012 9:10 pm
I've got the same style lamp as you and I find the light is very bright. If yours was dim, then it was probably on its way out. As its a fluorescent tube, you won't be able to fit an LED replacement straight in so you'd be looking at some serious modification or replacement of the complete unit.
weebrian
Post
by weebrian » Sun Nov 04, 2012 9:28 pm
I've just fitted one of these as a replacement for my tailgate light. The adaptor just fits in place of the bulb and the adhesive backing allows it to be stuck on top of the original.
http://www.ebay.co.uk/itm/140758953331? ... 1497.l2649
I've ordered another couple as they are seriously bright and very cheap. What I'd really like to know is if there is a switch built into the sliding door that would allow me to mount one above said door with the light coming on when the door is opened.
Post
by Simon Jones » Sun Nov 04, 2012 10:17 pm
That'll replace a conventional festoon bulb in the lamp by the tailgate, but you'd have to rip the inverter out of the fluorescent lamp to make it work.
Weebrian, you could always tap into the wiring to the existing switch on the sliding door. Don't have colour codes to hand, but you should be able to figure it out from the wiring diagrams.
Post
by g8dhe » Sun Nov 04, 2012 11:19 pm
Yup we got ours from the same place above however we went for
http://www.lampco.co.uk/results.asp?sea ... btn=search this just fitted but they don't appear to have any in stock at present.
