negative or positive ground connection on bongo ?
flyingdoc
Post by flyingdoc » Wed Oct 31, 2012 6:53 pm
HI Peeps, is it a negative ground on a bongo or positive ?
Re: negative or positive ground connection on bongo ?
Post by mikeonb4c » Wed Oct 31, 2012 6:57 pm
Its a negative earth if that's what you mean? Didn't know there had been any +ve earthed cars around for years :?
Velocette
Post by Velocette » Wed Oct 31, 2012 8:55 pm
mikeonb4c wrote:Its a negative earth if that's what you mean? Didn't know there had been any +ve earthed cars around for years :?
My old 1966 Mini van was positive earth. I remember I had fun fitting a stereo because the case was akways live!
Post by mikeonb4c » Wed Oct 31, 2012 9:24 pm
Ah Yes, happy days, I don't think I owned a -ve earth car until 1997 when I gave up driving firms cars. :-)
Dodgey
Post by Dodgey » Wed Oct 31, 2012 9:34 pm
Blew 2 radio cassette players in my mate's triumph herald before I discovered it was +ve earthed!
blobber
Post by blobber » Wed Oct 31, 2012 10:26 pm
I destroyed a few sets myself, same way #-o #-o #-o
Alan & Dot
Yes sir, I can Bongo !!
Post by Bob » Wed Oct 31, 2012 11:23 pm
Anything with an alternator will be neg earth.
Older dynamos can be either.
helen&tony
Post by helen&tony » Thu Nov 01, 2012 3:35 am
Come to think of it, when cars were positive earth...minis various, my old Standard, MG Maggot, Ford Consul convertible, amongst the many, I remember changing radios regularly...and that old +ve earth was normal...and the melting of the odd radio was, you say, a problem....rather causes me to remember...well................did I blow the odd radio......?????........NO....I always checked :lol: :lol: :lol: :lol: :lol: :lol: numerous cars had been fitted with alternate electrical systems, so it was a case of look carefully....and the coming of negative earth was always hailed as a ploy to arrest corrosion....did it make rusting less???????...did it 'ell.... :roll: :roll: 8) 8) 8) 8) ...damp + steel = RUST....ya can't change the laws of physics (or chemistry)...JIM :lol: :lol: :lol: :lol:
Velocette
Post by Velocette » Thu Nov 01, 2012 12:06 pm
helen&tony wrote:Hi
I never blew the radio but as I had wedged it in with bits of wood, but I do remember the odd shower of sparks if something earthed accidentally contacted it! :shock:
321Away
Post by 321Away » Thu Nov 01, 2012 12:26 pm
military vehicles and most boats are + ground, helps to prevent corrosion apparently!
Julian
Velocette
Post by Velocette » Thu Nov 01, 2012 12:43 pm
321Away wrote:military vehicles and most boats are + ground, helps to prevent corrosion apparently!
Julian
That's interesting because I'm sure people told me that the reason for the change to negative earth was to do with corrosion.
scanner
Post by scanner » Thu Nov 01, 2012 1:47 pm
Julian
Here's what t'internet says.
http://mechanics.stackexchange.com/ques ... ive-ground
and partly because positive earth encourages galvanic corrosion* of the surrounding bodywork - whearas with negative earth is is the much-easier-to-replace electrical contacts that corrode.
*Think back to school physics lessons with anodes and cathodes...
Velocette
Post by Velocette » Thu Nov 01, 2012 5:33 pm
scanner wrote:
Julian
I liked the bit about thinking back to Physics lessons but all I can recall is jibber jabber annodes jibber jabber jibber jabber cathodes jibber jabber and sitting on the back row dicussing how my mate was going to fit 12" extended Triumph forks to his BSA!
Diplomat
Post by Diplomat » Thu Nov 01, 2012 6:52 pm
Surprised nobody has yet mentioned changing the old cars from pos to neg earth. It was very easy.
I had a Morris Traveller (how I wish I hadn't let it go for £50 in 1972) and being a radio amateur I wanted to run neg earth equipment in it.
All we had to do was reverse the battery connections and If I remember correctly the generator field winding just needed a couple of blips of the new polarity to get rid of the old residual magnetism. None of the very few electrical items which a car needed in those days was fussy about the polarity including, as far as I remember, the starter motor. I may have had to reverse the power to that to stop it cranking the engine backwards but the only thing I can definitely remember was blipping the generator or dynamo, whichever we called it.
Frank
They flew, I took up naturism
Velocette
Post by Velocette » Thu Nov 01, 2012 7:39 pm
Diplomat wrote:Surprised nobody has yet mentioned changing the old cars from pos to neg earth. It was very easy.
Frank
Exciting it I think they used to call it?, My Mum had a Renault 4 with a dynamo and 6V electrics, I later had a 12V one . Come to think of it you can make a 6V dynamo run at 12V too it is just the regulator you have to change. You could on Bikes anyway.
