V6 owners - don't forget to change your fuel filters
Post by Simon Jones » Fri Oct 26, 2012 9:06 pm
Changed the fuel filter yesterday which is a bit more tricky than on the diesel as it's buried further up under the chassis:
Anyway, when I drained the fuel out the filter there was a lot of crud that came out. The good news was that it was not metallic, so I can only assume its dust and muck from the petrol itself. The only other thing it could be is from the rubber hoses.
Re: V6 owners - don't forget to change your fuel filters
Post by Northern Bongolow » Fri Oct 26, 2012 9:13 pm
it may be the ethanol in the fuel like you imply simon, stripping out the years of crud, try it again in 6 months and see how it looks then.
cheffy34
Post by cheffy34 » Sat Oct 27, 2012 1:30 am
Did mine couple year ago, must admit i didn't even look at what came out just chucked in the waste oil drum #-o .
