Charge and Sediment warning lights. Again.
Chris-W
Post by Chris-W » Thu Oct 25, 2012 12:27 am
OK, so these two lights are lit very dimly on tickover, and disappear quite promptly as the revs rise.
From reading the forum I understand that this is more than likely an alternator problem.
My question is this: Considering that the vehicle may have been standing for a while (there's proof of this elsewhere on the vehicle) is it possible that something might just need cleaning? Is it worth investing in some electrical cleaner spray before spending a shed load on a new alternator?
Also, could the battery be at fault? It either isn't holding it's charge (nearly flattened after very light use today) or is that because it isn't being charged fully in the first place.
Re: Charge and Sediment warning lights. Again.
Post by g8dhe » Thu Oct 25, 2012 10:56 am
Its almost certainly something wrong with the alternator, there is a specific signal from the alternator which feeds the two lamps, nothing else is involved.
the signal is on the link marked 3 which feeds the dashboard lights;
Chris-W
Post by Chris-W » Fri Oct 26, 2012 9:02 am
Yeah thought so. I'll get a some electrical cleaner on it, check the earths, and check with a multimeter before tackling that though.
Thanks.
Chris-W
Post by Chris-W » Wed Oct 31, 2012 2:51 pm
OK, got a multimeter on it:
Engine off, no load: SB 12.6V LB 11.7v
Engine running, no load: SB 14.1v LB 11.7v
Engine off, lights and fan on full: SB 11.75V LB 11.7v
Engine running, lights and fan on full: SB 13V LB 11.7v
Leisure battery I would say isn't doing anything, but what does the rest mean?
Chris
Post by Simon Jones » Wed Oct 31, 2012 5:02 pm
What type of split charger have you got? Some types take a feed to the relay from the alternator which drops the voltage to the point where the lights will glow dimly.
Chris-W
Post by Chris-W » Wed Oct 31, 2012 5:04 pm
Simon Jones wrote:What type of split charger have you got? Some types take a feed to the relay from the alternator which drops the voltage to the point where the lights will glow dimly.
I've absolutely no idea mate, I don't even know where it would be or what to look for?
On another note, the two lights indicate an alternator problem, yet the main battery seems to have the correct voltages?
Post by g8dhe » Wed Oct 31, 2012 5:46 pm
Chris-W wrote: Engine off, no load: SB 12.6V LB 11.7v
Those are the problem readings, under no load the alternator is just about acceptable, under reasonable load its only just about charging the battery, the alternator hasn't completely failed I suspect just one diode (of the six) has failed so far, but it won't be long especially with cold mornings and lights on meaning more current is required and hence more heat and others will fail within the unit.
At no point has the voltage risen sufficiently to even operate the split charge relay so hence the reason that the L/B has only a partial charge in it.
Chris-W
Post by Chris-W » Wed Oct 31, 2012 6:21 pm
New alternator it is then Image
Chris-W
Post by Chris-W » Fri Nov 09, 2012 8:16 pm
Well, here's the latest. I bought a decent leisure battery and fitted it in the second battery space. Went to the local Bongo garage to have secondhand alternator fitted. The first thing the guy did was got multimeter out and ran few tests. Straight away he said it was the split charge system. Two seconds later he put three fuses into the split charge wiring that had been removed, and instantly the voltage to the leisure battery jumped to 14 volts. That looks like a result. However, the two dashboard lights are still glowing, well more like pulsating, and so dim they can only be seen at night. More questions to follow.
Post by Northern Bongolow » Fri Nov 09, 2012 11:13 pm
when the leisure gets low because of bad charging, then the charging rate is improved it gives the fuses a spike that can pop them.
the original problem sounds like its still there, the alternator output rate sounds like its up and down. this may take your fuses out again.
did he put a meter on the alternator at all ranges of charge to see if its performing on tickover then when full demand etc.
Chris-W
Post by Chris-W » Sat Nov 10, 2012 9:00 am
I don't know what he 'exactly' did to be honest.
The leisure battery was fully charged, so little chance of wrecking it, but I'll be able to monitor it's charge state. I would expect the voltage to get less and less as time goes on and it doesn't get enough or any charge.
Post by Simon Jones » Sat Nov 10, 2012 10:58 am
My thought is that it's just down to the type of split charge that is installed. I made one myself using a relay controlled by a feed from the thin wire on the alternator. It did the job, but the lights glowed dimly. I soon replaced it with a proper kit.
Next time you're around in Salisbury, let me know and I'll take a quick look if you like.
Chris-W
Post by Chris-W » Sat Nov 10, 2012 11:09 am
Appreciate the offer, thanks. PM sent.
