2 questions only !!
Lins
2 questions only !!
Post by Lins » Mon Oct 22, 2012 9:07 pm
What height restriction barriers can I get under ? and what tyre pressure should I use for the front and rear tyres...thanks !!
kentait
Re: 2 questions only !!
Post by kentait » Mon Oct 22, 2012 9:15 pm
Height restriction: if it has an auto free top (aft) 2.1 metres
Lins
Post by Lins » Mon Oct 22, 2012 9:40 pm
Lins wrote:What height restriction barriers can I get under ? and what tyre pressure should I use for the front and rear tyres...thanks !!
thanks
MountainGoat
Post by MountainGoat » Mon Oct 22, 2012 9:43 pm
Avoid most multi-storey car parks. You may be able to get under the height barrier at the entrance but the height available on the interior ramps is often a different matter.
Tony
the laird
Post by the laird » Mon Oct 22, 2012 9:44 pm
34psi for fronts and 36psi rears 2psi more if converted
Post by Bob » Mon Oct 22, 2012 9:59 pm
As said, avoid all multi stories. They measure the vertical separation, but as Bongy goes down the ramp she will pivot on the rear axle and the bit behind that will go up. There will be concrete here.
A few have been caught by this.
2.1m 6'10"
