Front differential oil seal please help!
sunnyjim82
Post by sunnyjim82 » Mon Oct 22, 2012 7:03 pm
Hi I'm after an oil seal for my front differential that has decided to spring a leak 4 days before I plan to drive to Northampton! Please can anyone help with the part or direct me to where I may obtain one pretty please ;-)
It is the near side shaft seal that sits inside the differential as the shaft passes through it.
Re: Front differential oil seal please help!
Post by teenmal » Tue Oct 23, 2012 11:46 am
Your friendly Mazda/Ford dealer should be able to supply the part M0A727238A.
Check Number with dealer.
Cheers.
Post by Northern Bongolow » Tue Oct 23, 2012 10:05 pm
check the diff breather is clear on the top, this allows the hot oil to breathe, if blocked it expands and pops a seal.
