mapping? - 2 litre
DILLIGAF
mapping? - 2 litre
Post by DILLIGAF » Sun Oct 21, 2012 3:23 pm
Hello knowledgeable ones, i know nothing about techie stuff so could someone with the knowhow advise me, i was talking with a seemingly knowledgeable chap parked in asda the other day and after mentioning mpg (worked it out when we first bought "VICTOR" by filling right up, turning clock back to 0, then driving till allmost empty ,fill up taking note of mileage and litres and doing the maths, came out at 28mpg, he said if you get your engine "mapped" it can make a big differance. First is this correct? and if it is whats the cost? where would it be best to get it done? (cornwall) any help would be wellcome. Brian.
being a philosopher, i have a problem for every solution.
DILLIGAF
Re: mapping?
Post by DILLIGAF » Sun Oct 21, 2012 3:25 pm
Forgot to say "Victor" is 2.0ltr petrol. #-o
Re: mapping?
Post by g8dhe » Sun Oct 21, 2012 4:22 pm
He is right in one sense modern vehicles ECU can be remapped, however your not dealing with modern vehicles!
The diesels can't be remapped and I've not heard that the V6 or 2.0L can be either.
DILLIGAF
Re: mapping? - 2 litre
Post by DILLIGAF » Sun Oct 21, 2012 6:19 pm
Thanks Geoff, i thought it sounded too good to be true, if it was that simple everyone would have done it i supose, just a thought though. Brian.
Bongoplod
Post by Bongoplod » Sun Oct 21, 2012 11:25 pm
DILLIGAF wrote:Hello knowledgeable ones, i know nothing about techie stuff so could someone with the knowhow advise me, i was talking with a seemingly knowledgeable chap parked in asda the other day and after mentioning mpg (worked it out when we first bought "VICTOR" by filling right up, turning clock back to 0, then driving till allmost empty ,fill up taking note of mileage and litres and doing the maths, came out at 28mpg, he said if you get your engine "mapped" it can make a big differance. First is this correct? and if it is whats the cost? where would it be best to get it done? (cornwall) any help would be wellcome. Brian.
I agree with Geoff.
However as a past owner of 2 x 2.5 deisels,and now a current owner of a 2 itre petrol,i must say if i was getting 28 mpg,i would be VERY happy.
Ive had mine 2 yrs and have every petrol reciept for every fill up since ive owned it. I also brim it and do the maths,but only get that sort of mpg on a run,Local driving gives me 18-20 mpg :(
Brian
Post by Bob » Sun Oct 21, 2012 11:35 pm
And don't forget messing with anything can play havoc with your insurance. :(
DILLIGAF
Post by DILLIGAF » Mon Oct 22, 2012 5:21 pm
hi Brian, 28MPG is a mix of what i call longish runs and local driving, checked it three times, first time was 24, second time 28, third time was 26. The first check was after a run to lands end and back, only 80 miles, with a couple of runs up to devon and local running, the second was driving up to exmoor and running around while camping up there, the third was mostly runs to Truro,which is a 45 mile round trip, so after what youv'e said ithink i'll leave well alone and be thankful !!!!!
Brian.
Ian65
Post by Ian65 » Sun Oct 28, 2012 10:40 am
Might be worth contacting Celtic tuning at Roche, they may be able to help but not sure if the tune petrols
Made a big difference to my Transit though
DILLIGAF
Post by DILLIGAF » Sun Oct 28, 2012 10:54 am
I'll give them a ring and see what they say Ian, thanks for the info. =D>
Ian65
Post by Ian65 » Sun Oct 28, 2012 11:04 am
Let us know the outcome, may get the v6 done
DILLIGAF
Post by DILLIGAF » Sun Oct 28, 2012 11:06 am
will do.
Post by Muzorewa » Sun Oct 28, 2012 11:09 am
But if you remap a 2.0 petrol for economy, it's not going to have enough power to get out of its own way :wink:
Ian65
Post by Ian65 » Sun Oct 28, 2012 12:19 pm
Its not just a remap for economy, it also increases the power. My Transit went from 140bhp to 185bhp, its all to do with the power to weight ratio. Obviously if you drive it hard after a remap fuel economy wouldn't be as good as before but for normal driving its better.
My Transit went from averaging 28mpg to an average of 35mpg which when I was doing European courier work doing roughly 3000 miles a week big savings were made. My business partner had the same van, but un-mapped,and on a regular run to Italy I used £150 less in fuel running at roughly the same speeds. 70 to 80 mph
rapiddescent
Post by rapiddescent » Sun Oct 28, 2012 11:38 pm
Most remaps nowadays (eg on ford transit) are for turbo engines where the ECU can be reprogrammed and change the behaviour of the waste gate on the turbo. Some use piggy back ECU's others just rely on reprogramming. Most modern engines take a cautious approach to save warranty claims etc.
Remaps on non turbo engines do very little.
Ford Freda owning mountain biker dude
DILLIGAF
Post by DILLIGAF » Mon Oct 29, 2012 10:25 am
Just rang CELTIC TUNING Ian, they don't work on bongo's at all and when i asked if he knew anyone else that would do it the guy said it was as RAPIDDESCENT says, non turbo petrol it wouldn't work, so another idea bites the dust. :(
