drive shaft
drive shaft
Hi got a cluncking noise from the o/s front think its a drive shaft been under quickly but cant feel any freeplay is this normal? will i have to strip a corner down? see on ebay they are handed but on bongo fury parts cv joint fits all bongos so i guess the joints arent handed? what are cv joints like to fit ide rather have a new joint me thinks the price aint that differant. Ta
Re: drive shaft
Are you sure it's a CV and not the drop links?
When CVs start to go you will usually notice it on lock, if it's happening on the straight have a look at the drop links and and roll bar bushes first, it's an easier job than changing CVs.
Re: drive shaft
yeh its worse in left hand lock so maybe the cv ta.
- Simon Jones
Re: drive shaft
Drop links are a lot more common (and cheaper) to replace than CV joints. Bear in mind when you're going round a left hand bend, the body will roll to the right and this changes the weight distribution on the suspension such that components that were under pressure are then free to rattle around.
CV joint noise will vary with road speed whereas drop links will change with road conditions.
