Hi Julian, I think most decent timers have an interlock that prevents the unit from changing with the ignition key removed while the engine is running.321Away wrote:Technically a turbo timer makes your insurance void, the conflict between antimer and an immobiliser is the immobiliser waits typically 45 seconds from the ignition switching off before arming, the timer keeps the ignition on, you can get timers that interface with the handbrake (as most do) and the door switches, so the vehicle will instantly stop if the door is opened or the handbrake relaeased. The only real and safe way to do it is as mentioned to buy an alarm system with integrated timer and immobiliser, even then i'm not sure where insurance would stand as they usually flat out wont accept timers at all as someone could potentially jump in your car, turn the timer up to 10 mins, snap off the steering lock and drive away, probably easier just to kick your head in and take the keys tho lol
Julian
