knocking
Posted: Fri Oct 12, 2012 9:58 pm
by stefan442
I get a knocking sound coming from the rear left when I make a hard left turn. Right is fine... any ideas?
Re: knocking
Posted: Fri Oct 12, 2012 10:59 pm
by M 80NGO
Is it a constant knock or a single knock, could be exhaust catching rear axel or maybe a broken coil spring on the very last coil
Re: knocking
Posted: Fri Oct 12, 2012 11:45 pm
by stefan442
Single knock. Thanks for reply: )
Re: knocking
Posted: Sat Oct 13, 2012 1:05 am
by Driver+Passengers
Antiroll bar or bush?
Re: knocking
Posted: Sat Oct 13, 2012 1:13 am
by Blueskai
Check the rear antirollbar drop link. If the rubbers are perished they knock. replace both if you do need to change one Fairly cheap and easy DIY fix if the self locking nuts are not too tight.
Re: knocking
Posted: Sat Oct 13, 2012 1:19 am
I meant to say that, too. :oops:
