knocking
stefan442
knocking
Post by stefan442 » Fri Oct 12, 2012 9:58 pm
I get a knocking sound coming from the rear left when I make a hard left turn. Right is fine... any ideas?
M 80NGO
Re: knocking
Post by M 80NGO » Fri Oct 12, 2012 10:59 pm
Is it a constant knock or a single knock, could be exhaust catching rear axel or maybe a broken coil spring on the very last coil
stefan442
Re: knocking
Post by stefan442 » Fri Oct 12, 2012 11:45 pm
Single knock. Thanks for reply: )
Driver+Passengers
Re: knocking
Post by Driver+Passengers » Sat Oct 13, 2012 1:05 am
Antiroll bar or bush?
Image Image
Blueskai
Re: knocking
Post by Blueskai » Sat Oct 13, 2012 1:13 am
Check the rear antirollbar drop link. If the rubbers are perished they knock. replace both if you do need to change one Fairly cheap and easy DIY fix if the self locking nuts are not too tight.
Driver+Passengers
Re: knocking
Post by Driver+Passengers » Sat Oct 13, 2012 1:19 am
I meant to say that, too. :oops:
Image Image
